Question about Whirlpool Kitchen Ranges
Gas unit, top burners light, but oven will not light?
Model # SF385PEYQ2, would like to know where the pilot is and if is a standing flame or elec.
    President:
  • 2,992 Answers
The oven uses an electric igniter which needs to come on and heat before the gas valve will open. You can reach the igniter by removing the oven bottom (remove a couple of screws and lift it out) and then removing the baffle plate (one screw holds it). When you turn on the oven you should see the igniter glow if it's working correctly. If it doesn't, check it for visible breaks or test with an ohmmeter. A very high or infinite resistance means it's bad. If the igniter glows but no gas flows, the main valve would be suspect. A number of vendors online have parts available.
Posted on Jan 09, 2009
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
I have a Hardwick propane stove, 4 burners and oven. The stovetop burners work fine (need a match), but now the oven does not ignite despite the pilot light working fine. I have brushed the pilot light...
Hello Patrick,
WHen you turn on the oven/broiler does the size of the polot ligh increase in size??
the way it is suppose to work is...thier a small free standing polot light and when ya turn on the oven the size of the pilot is suppose to increase and heat a little bulb that is connected to a wire that is mounted to the pilot burner and when that bulb heats up it will allow the main gas to flow into the oven(not pilot burner).
If the size of the pilot does not increase it could be caused by a clogged pilot burner. the way to determine that is TURN OFF GAS SUPPLY...disconnect gas line from pilot burner and turn on gas to unit, light that tube with it disconnected from pilot burner and turn oven on and see if size of flame drastically increases...if it does turn gas off and remove and replace pilot burner
if flame sizedoes not increase the problem is going to be the thermostat
If the pilot does increase and heats the bulb on the pilot burner the problem will be with the gas valve that,that bulb in the pilot burner accathes to is bad .
now chances of the thersostat still being available is very slim if the pilot burner is clogged and needs replaced they are still available their is 2 of them one has the mounting plate on the left and one is on the right.
here is what they look like
oldtech2332_148.jpgPart number for this one is 1898-021 notice how the mounting tab is on the right
oldtech2332_149.jpgthis one is pt# 1898-022 the tab is on the left
That when performing a quick search on google is pretty much all that still available teh thermostat (would need model number) is doubtful to find also a good chance the gas valve is also no longer available
Good luck,
GENE
Oct 27, 2011 | Kitchen Ranges
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
Instructions
  1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
  2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
  3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
  4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
  5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
Jan 26, 2011 | Ovens
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
I have a Frigidaire gas range, model #FGF316BSA. When I attempt to operate the oven it won't light. The glow bar comes on but nothing happens after that.
Hi
Thanks for using FixYa. From what you have described it seems that possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Kitchen Ranges
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
How do you light the pilot on a GE stove The top of the stove works
Hi, If this model has a standing pilot, use a lighter and put the flame to the back center next to the burner assembly. Most newer models have electric ignitors now. It is fastened to the burner assmbly on the laft side.
If this an electric ignitor, turn the oven on and see if the ignitor glows. These ignitors are a very common problem and will probavly need replaced.
Please let me know if I can assist youu further.
Vic
Jul 03, 2009 | GE JGRP17 Gas Single Oven
Kitchen Ranges Logo
116 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
