Question about Philips GOGEAR SA6045 MP3 Player
My go gear doesnt work
"Get a firmware upgrade...whenver you reset the device it reset the firmware install..so get the firmware upgrade and that should solve the problem you are having..hope this solve the problem"
how can i get it if my go gear is frozen and wont be read by the computer
  • fran_lopez19 Jan 17, 2009
    "This is a way to force the PC to recognize the GoGear and solve your problem. Make sure the hold/lock switch is not engaged first. Note: These instructions only work for the SA6045 - if your Philips is a different model #, these instructions may or may not work:
    Triple Reset for Philips’ GoGear:
    Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
    After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
    -Tha Mp3 Doctor"
    My screen just stays black and still not recognize it.....
    My screen is always black it just wont turn on
  • 8,596 Answers
-Tha Mp3 Doctor
Posted on Jan 17, 2009
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
My mp3 player will not work, I reset it many times and it also will not sync with my PC.
If you have Windows Vista or Windows Media Player 11, go ahead and upgrade the firmware at www.usasupport.philips.com
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Update" tab
As long as the hold/lock key is not engaged, the following will force the PC to recognize most GoGear mp3 players:
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 31, 2009 | Philips SA3125\02 MP3 Player
DWL 2700 AP wrong firmware install
hi...
since you upgraded a different firmware try updating the firmware again with the correct firmware if it works fine if it doesnot then the router had gone bad,,
and for GeminiBS reset the router to the factory default since the firmware was not done in a proper manner may be it had interruptions..once the hard reset is done the computer is restored back to the default so that you can use the device..
vedhick
Feb 13, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Mp3 doesnt go to its menu
Upgrade the firmware
www.philips.com/support
enter country
enter model #
click on model #
click on software & drivers
click on firmware upgrade - software
or, just open the Philips Device Manager and click on "Update"
Sep 01, 2008 | Philips SA5125/37 MP3 Player
PHILIPS GO GEAR
Uninstall the device and software completely first, and then reinstall it. If that still fails, get the firmware upgrade from Philips website - will reload. Note: this player is not compat with Vista or Macintosh.
Jun 18, 2008 | Philips GoGear SA178 MP3 Player
Sakar 49152n webcam
your computer might not recognize the sakar 49152N wecam if you connect it to your PC through a USB 2.0 hub if the hub also has slower USB 1.1 devices connected to it. This is a problem with the sakar 49152N wecam firmware, and downloading a firmware upgrade.
As a general word of caution, upgrading a device’s firmware is similar to editing your PC’s registry. Be absolutely certain you know how to perform the necessary steps before actually carrying them out. A botched firmware upgrade can irrevocably damage your hardware.
Mar 08, 2008 | Cameras
IRiver H10 20GB
Try this link to get the latest firmare upgrade for your device and if you dont have the latest windows media player install in your computer..you need to upgrade it so it can install the device driver for you..
the link for the firmware upgrade is
http://drivers.softpedia.com/get/FIRMWARE/Iriver/Iriver-H10-Firmware-Release-253.shtml
and also install all the latest update for your computer from www.microsoft.com
if that doesnt solve the problems your problem uninstall the device and reinstall the device
I hope this help
Thank you
Computerrep
**Please rate accordingly..**
Jan 30, 2008 | iRiver H10 MP3 Player
I turn on my Go Gear and it freezes
Jan 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Frozen!
I would recommend you to format the device inside WMPand if that doesnt work try to do a firmware upgrade...there is a problem with your firmware.....
Jan 04, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
147 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
