Question about Sony Playstation 3 (PS3) Console
Playstation 3 Hey my system wont turn on, and I know for a fact it didnt overheat... you live in the US?  I know overseas they are exchanging for free... does that apply to the US also?  My system is the original 60GB with a built date of Dec. 2006
  • 33 Answers
PS3, The amazing device by sony also has some common problems like Xbox and Wii have. But good news is that these all problems can be repaired with the help of many DIY Guides, one such guide available at PS3 Repair Blog
Posted on Mar 06, 2009
  • 344 Answers
Hello. Sony will do the free exchange/repair if the warranty hasn't expired. Since it's an original 60GB from 2006 they will most likely turn you down and offer to repair/replace the unit for $150 (US).
If there are no lights on at all then it is a bad componant inside the power supply, which can be replaced fairly easily. If lights come on in this sequence....green, yellow, red followed by 3 beeps then your system isn't easily repairable and you would be better off paying the $150. Thanks!
Posted on Jan 09, 2009
My husbands game turned off while he was playing it and wont come back on, what should i do?
If your system turns of but after 3 seconds it shuts off and beeps 3 times then you have what its called YLOD, its a chip that gets overheat after normal daily use. in order to get your system repaired you either find a local video game repair shop or send it to sony for a repairs.
Thanks
www.1RepairStop.com
Sep 10, 2011 | Sony Playstation 3 (PS3) Console
My ps3 screen wont show when i turn the ps3 on.
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 28, 2010 | Sony PlayStation 3 40GB System
Playstation gets really hot after about 20 mins then freezes and wont load anything
That would indicate that a fan is not working.
As in any computing device, heat is the enemy of the system. The cooler the system runs (to a degree) the better it runs. When the device gets too hot, the processor overheats and it causes a system freeze. You should return/exchange the console where you purchased it. The alternative is opening the device, voiding any warranty, and a risk of breaking the unit.
Admittedly, a fan repair is relatively easy once you get inside the case. Usually, it's just a couple screws and the fan falls out. The fan will probably have a harness connecting it to the motherboard, if not, it just comes down to splicing a couple wires together.
Hope this helps!
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
Ps3 will not play any games
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 07, 2009 | Sony PlayStation® 3 (60 GB) Console
My controller connection to my PS3 constantly dies after about 45 minutes whether its plugged into the USB port or not. How do I fix this?
hey i had my ps3 for about 8 months or so i got the message i did everything unplugged it didnt work held power button 10 seconds restarted it nothin- mine makes a weird noise and the orange light saying its loading wont turn off if it does that it pretty much means A. your hard drive is fried B. your hard drive isnt responding with system C. you turned off your ps3 while loading something and it fried it i think is what happened to me
Dec 11, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont come on!!
Hey, your screen settings may need to be reset. You can reset your playstation 3 screen settings by first turning of the playstation three, then turning it on by hitting the power button on the console and hold it for 5 seconds. You should hear it beep several times and then it should work.
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wont read discs
Just return your system or exchange it. I have same problem 2 times. First with 40G system only 2 weeks old. Exchanged that one with 80g system. This time it last 3 weeks. Now returned and got my refund back. Will not buy PS3 again until they solve this disc drive issue.
Dec 12, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
106 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
