Question about Lexmark X75 All-In-One InkJet Printer
When I go to turn on the computer/printer the printer sounds like it is stalling while turning on. It does make a loud clunking noise when I turn it on. I am able to print some things but it doesn't always print a full page. My black ink cartiage is full, but the color grid is gray with a question mark. We can not see anything in the printer as far as paper clips etc. Thank you Kim
  • 191 Answers
Your case sounds like the cartridge driving probem
1) check the cartridge driving bell is right on the way, and check the bell no gears damage, need to change if any damage
2) fill oil on the cartridge rail to make it lubricated
3) check the bell sensor open side cover to find out all sensors are in the right position and click normal,
Posted on Feb 06, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    any help for you please send a feedback thanks
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - GM-Trucks.com
www.gm-trucks.com > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
www.jeepsunlimited.com/.../showthread.php?...loud-clunking-noises
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums
forums.tdiclub.com > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
Dec 26, 2015 | Cars & Trucks
What is causing my explorer to **** & clunk with a loud grinding or rubbing noise when i turn corners?
Sounds like you have either ball joint issues, or problems with the CV joints. The other possibility is a problem in the transfer case causing the front axle to bind. You can physically look at the CV joint boots to see if they are torn open and many times you can grab onto the axle and give it a good tug to see if it will move..it should not.
Mar 07, 2014 | 2002 Ford Explorer
Loud clunking noise
check engine mountings and front ddie shafts
Dec 30, 2013 | Cars & Trucks
LOUD CLUNKING NOISE IN REAR WHEEL AREA WHEN TURNING LEFT
sounds like either a sway bar end link or shock, more towards the end link tho
Feb 24, 2010 | 1998 Ford Taurus
"clunking" noise when it turns itself off
the compressor mounts are bad . or the internal insulators in the compressor are bad . . is sounds like the internal mounts . at 9 yrs . . mm hope this helped . ,mm
Feb 03, 2010 | Refrigerators
Im not sure if it is electrical, jet ski ran fine, stalled, soounded like it was trying to turn over a few times, now when you try to start it thats all you hear is a loud clunk
do a compression test sounds like it locked up if motor will not turn then u need to pull the heads and inspect it a clunk is never good....
Jun 29, 2009 | Boating
I have a Dell A920 printer. Carriage stall error
Try this trick. Turn off the printer, reach in and manually move the carriage to the other side of the printer. Then, unplug it, plug er in and try again. If that doesn't work then it's most likely a dead unit.
Feb 26, 2009 | Dell 962 Photo All-In-One InkJet Printer
Loud clunking noise underneath fridge
its sounds like a spring is broken inside your compressor this you cannot repair you need a commpressor replacement or you can check if your fridge is levell sometimes by levelling the fridge it may reduce the sound thans from gilles
Dec 10, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Sterring problems
Sounds to me like you might have to replace your cv shaft they tend to make an odd clunking noise at regular patterns in turns.
Jun 29, 2008 | 1999 Chevrolet Cavalier
Lexmark X75 All-In-One InkJet Printer Logo
199 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
