Question about Kyocera Mita FS 3800 Laser Printer
Wast Toner Box is filling up quickly.
We have now replaced the waste toner box 4 times this week and the last time we noticed different layers of colors in the box. Normally the waste toner is a gray-black color.
    Problem Solver:
  • 10 Answers
You say there are colors in the box but the 3800 is not a color printer. If it is one of the desktop color printers there is a setting change that may help. It is a service mode setting called "T7". If you print documents that don't use much toner this setting will reduce what is dumped in the bottle during operation. If you call the Kyocera End User Help Desk they can remote in and make the change if they think it will help. 800-255-6482
Posted on Jan 09, 2009
Reset wast toner box on 9970cdw
Remove the full waste toner box per manual. Wear breathing protection as there will be toner dust in the air. Place flat in a work area and remove the 6 screws retaining the black box cover and carefully remove cover with box still flat on the work area. Be careful, the box is full of waste toner powder. Dispose of the waste toner by tipping into waste container, being careful not to inhale the powder. Use a blower or vacuum to remove final traces of waste toner from the box and clean all surfaces with a clean cloth. Place the box flat on bench to inspect the clear sight-glass at the front. Inside will be a black flag which should be down on the bottom of the sight glass. If not, there is still waste toner in the front of the box which needs to be shaken or blown out. Replace the cover and 6 screws and replace the waste toner box in the printer. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
Jul 03, 2014 | Brother WT300CL Waste Toner Box
Replace the waste toner box
Please write me your copier brand name and model name.Some times when waste toner is full the tank than show massage replace the waste toner box.You should clean the waste toner than fix this massage.
Oct 20, 2013 | Copystar Ri-2530 Printer
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Sharp MX 2300N - Toner collection unit needs replacing, not sure what this means. We replaced toner cartridgers very recently and assume this is a container that collects loose toner particles. How do...
REPLACING THE WASTE TONER BOX
The waste toner box collects residual toner that is produced during printing. When the used toner box is full, the display
will show "Replace used toner container". Follow the procedure below to replace the used toner box.
Open the front cover.2
Release the used waste toner box.
The waste toner box will fall forward as shown.
Gently support the box with your hands as you let it fall forward
as far as it will go.
fmtx.png Remove the waste toner box.
Hold the box by both hands and lift it up slowly.
If the waste toner box falls too far forward, it will not be possible
to remove it. (Remove the box when it is at an angle of about
30 degrees.)
Install the new waste toner box.
Insert the box from above at a slant. (The direction opposite to
when you removed it.)
Push the waste toner box into the
machine.
Push the box in until it clicks into place.
Close the front cover
Hope this helps.
Feb 07, 2011 | Sharp MX-2300N Color Copier
Samsung clp 315 printer shows "replace/install
Hi there your printer wast toner drum is full. So just remove that and make empty the drum & then refill the toner box. now use. Thanks.
Dec 22, 2010 | Samsung CLP 315 Laser Printer
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Kyocera 3035
Stupid question but make sure that there is nothing on the glass surface underneath your document feeder. Be sure to get the main glass clean as well as the little strip of glass to the left. If this didn't fix your problem than you need to do a little more cleaning.
When was the last time you changed the toner? In the toner box you should have gotten a small grayish blue box with a plastic top and felt head. There should have been instructions on how to use this little cleaning tool but what you need to do is to remove the waste toner bottle being very careful not to spill the waste toner all over yourself. Before you do anything else you should gently take out the green square handle. Now behind the space where the waste toner bottle is located you will notice a small hole that fits the little blue box minus the cap. Gently place the blue box (peg first) into the hole (should only fit one way but the felt tip should point to the right) and gently move the green handle back and forth 3 to 4 times. Take the blue box out and throw away, put the green handle back in and than replace the waste toner bottle.
If you don't have the little blue box than call the company you got your copier from, they should be able to help you.
Hope this helps.
Henry
Jun 02, 2008 | Kyocera Copystar CS-5035 Copier
Printer toner refilling
you can fill it by yourself.
1. buy good qulity magnatic toner powder.
2. basic for oppening 12a toner is 2 SIDE SMALL PIN, YOU CAN EITHER PUT THESE PINS INSIDE THE TONER WITH THE HELP OF HAMMER AND NAIL.OR OTHER TRICK IS TO FIRST OPEN THE GEAR SIDE TWO screw BY PHILIPS SCREW DRIVER and pick up drum then with the help of l type sharp longe nail try to pull pins from inside to out side this by process you see you get two part of toner cartridge one is wast chamber another is main chamber smaller one is wast cleane it .
open the both side of main chamber by unscrewing 4 screw ond pour the toner power powder in that main hopper and do all the steps in vice versa. your toner is filled TAKE A TEST PAGE.
I can frovide you photos step by step mail me inkcity@rediffmail.com if neded
Jun 01, 2008 | HP LaserJet 1012 Printer
CANON 5870 ERROR CODE
its mean that wast toner box is full,empty waste toner box
Sep 25, 2007 | Sharp AR-C160 Color Copier
Kyocera Mita FS 3800 Laser Printer Logo
161 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
