Question about Ovens
Oven not heating
Hob is fine, but oven not heating up at all. Have no instructions, wondering if to do with timer, can anyone help?
  • Ovens Master
  • 3,463 Answers
If it has a digital timer, make sure it is set to auto and not manual, as oven will not heat if it is on auto.
If it is a anolgue timer ,then it should be showing a hand symbol,if it is not, then turn knob or dial until it does.
If these settings are o/k, then could be a faulty element.
Plz rate my solution.
Thanks.
Posted on Jan 09, 2009
We have a smeg uk80fxm1 the oven cuts out after about 20 minutes and the timer goes off too. It comes back on after a long time but keeps doing the same thing. Full power does not go as the hob spark...
YOUR HEATING ELEMENT COULD BE BAD & NEEDS REPLACED. THERE COULD BUILD UP ON THE HEAT ELEMENT. THERE COULD BE A SHORT SOME WHERE IN THE WIRES. TRY CLEANING EVERYTHING INSIDE OVEN WITH VINEGAR & WATER SOLUTION ON A RAG BUT DRY IT OFF WELL BEFORE TURNING BACK ON.
Feb 01, 2015 | Smeg Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
Hi We have a zanussi ZCE 7550 double oven cooker. The bottom oven broke (with a flash and bang), so we replaced the element at the back as it was burnt out. The top grill and hob are still...
Hello starsevern!! Did you get your cooker fixed, what was the problem?
I have a Zanussi ZCE7550, but apart from that I'm in exactly the same predicament as you in the post you made on Sep 18, 2010...
Can anyone help with a suggestion please???
Sep 18, 2010 | Zanussi ZDQ495 Electric Double Oven
Electric oven will not switch on. No heat, no fan. There is a timer display that is counting up and has the word AUTO showing. The gas hob works normally. How can I turn the cooker on?
Hi. You probably have to switch the oven onto manual control. Auto would turn oven on at a preset time. Is there a button with a hand symbol on it? This might be manual. Timer should show clock when in normal manual operation.
Aug 22, 2009 | Tecnik Ovens
I really need some help , a family member has given me a belling format 661 , the hob and the top oven works but the actual oven doesnt at all the fan isnt moving and there is no heat .
If it has a timer, make sure it is set to manual.
If it is digital try resetting timer, if anologue then a hand symbol should be showing.
Dec 06, 2008 | Ovens
Smegg Oven Model Number and problems ... please help =)
It looks like an S551X-5, I think the timer is a safety mechanism, maybe just set it to full when in use and turn it off when you finish.
Go to http://www.smeguk.com/KitchenStudioLine/Product/S551X-5.aspx to see features, etc.
Jan 28, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Oven doesn't heat up
WHAT KIND OF OVEN? NEED MORE INFORMATION
Sep 10, 2007 | Tecnik TKC195/3 Electric Single Oven
Ovens Logo
118 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
