Question about HP PhotoSmart 7760 InkJet Printer
Not printing at all
I have connected the printer to the p.c. blut it will not print.
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
I can't get my chromebook to print to a my HP printer
Are you using the Google Cloud Print? If you are, you need to install a software called proxy, as part of the Chrome OS. The proxy will register the printer with the service.
Printer turned on? Classic printer installed on another computer?
When you first connected your printer to Google Cloud Print, you had to use another computer to enable the Google Cloud Print connector. Is the computer you used to enable the connector turned on? are you using the same user account you used to connect the printer to Google Cloud Print on your linux? If not, log in using the same Windows, Mac, or Chrome user account you were using when you connected the printer with Google Cloud Print.
If using a cloud ready printer; are you using the same user account you used to connect the printer to Google Cloud Print on your linux? If not, log in using the same Windows, Mac, or
Delete the printer and reconnect the printer with Google Cloud Print. Are there duplicate printers on your Google Cloud Print page?
In Google Chrome, select Options > Show advanced settings > Sign out of Google Cloud Print.
Visit the Google Cloud Print page and click on Printers. Delete any duplicate printers (printers with the exact same name) and then sign in to Google Cloud Print again to print.
Nov 24, 2013 | Samsung Chromebook Xe500c21 12. Led...
I have print server d-link dpr-1020 connected to laser printer hp P1006. My PC is running under windows 7 Pro. Print server is connected to linksys wrt120n router by cable. My PC is connected to the...
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Nov 05, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Printer is connected but does not print
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
Hi, I connected the printer server GPSU01U to a dlink 524
When you connect the print server to the router, does the lights lit? have you tried to reset the print server (reset button is on the side of the print server). press the reset button for 10 seconds, after 10seconds, while still holding the reset button power cycle the print server (unplug then replug the power cable) then release the reset button. Try to find the print server using the PS admin.
May 17, 2009 | IOGear (GPSR01U) Print Server
Connecting the WGPS606 to Dell AIO 962
Try installing a lower end printer to the same port. For example HP LaserJet 3.
Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Adding a second printer to a d-link priter server
You need to connect the second printer to your print server then install the printer driver to your computers. If your print server has a printserver driver, run that so it will automatically find the new printer for you.
Jul 28, 2008 | D-Link DPR1260 Rangebooster G...
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Print server won't speak to printer
If I am correct, you are connecting the print server to the Xerox with a parallel cable.  If so, you are printing two different ways when you connect with an ethernet cable.  When you connect the printer with an ethernet cable you are probably printing TCP\IP to the IP Address of the NIC Card (in the printer).  When you connect with a print server, the print servers IP Address becomes the one you would use as the port for the printer object in Windows Printers & Faxes.
Oct 12, 2007 | Computers & Internet
HP PhotoSmart 7760 InkJet Printer Logo
27 people viewed this question
Ben Johnson
