Question about Toshiba 50H81 50" Rear Projection Television
No picture no sound red light turns on and off when pressed
I was playing a video game and the tv suddenly turned off then it turned right back on, but no picture or sound, does anyone have a suggestion?
  • kevin619 Feb 10, 2009
    My son was playing the Wii when the TV whent black. Red power light is flashing steady, I've unplugged unit twice last time was for about an hour still same problem. About 2 years ago we had to have the power sending unit(I think that what it was) repaired since there are no replacement parts available. Any help would be greatly appreciated.
  • Toshiba Master
  • 5,568 Answers
Your description of events is helpful and points to the power supply as the culprit.  This is probably on a separate board (they are often out-sourced) and may be easy to replace.  You should be able to identify the board since it will be smaller than the main board and have larger components on it including one or more transformers and larger capacitors (plastic shrink-wrapped cans of different sizes).
If you want some confidence before rushing out to buy one or have this one repaired, you could pick up a can of 'freeze spray' from any electronics supplier (Radio Shack may have it too), pull your set from the wall, loosen the screws on the access panel behind (don't remove it; that may improve cooling and temporarily mask the failure), keep the freeze spray handy so if it fails, you can pull the panel and start spraying the PS board. I'd start with the small to medium sized capacitors since these are often at fault once aged.
Good luck-
Posted on Feb 13, 2009
TV turns off after 2 minutes
The power supply may be failing.
Oct 27, 2017 | Daenyx Televison & Video
Tip
PS3 Has no Video - Simple fix!
When you attach your Play Station 3 to an HD TV through an HDMI port, the Play Station 3 will ask you if you wish to switch to HD Mode.
However, if you decide to move it to another TV that is not HD compatible, you will get no picture because the Play Station 3 is “stuck” in HD (HDMI) mode.
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
That’s it! You can play your Play Station 3 again!
on May 13, 2010 | Video Game Consoles & Games
Tip
How to change or reset PS3 Video Display Mode
on Mar 12, 2010 | Video Game Consoles & Games
My picture started flickering the other night while playing a game. Then I went to turn it on today and I can't get a picture, there is still sound however. Thinking maybe a video card problem or something...
Its sounds like a video cord problem, if you are hooked up by the yellow red and white cords to your TV, adjust them until the picture returns, its a VERY common problem on EVERY TV and console since the SNES. Could also be the plug on the back of the PS3 if you just play with the cords your problem should resolve.
Jan 12, 2011 | Sony Playstation 3 (PS3) Console
Moved playstation to friends tv played fine. Connected back to my tv power lights come on but No sound or picture yet all cables are ok
You need to reset the display, follow these steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the PS3 to start up with normal display settings. If you are using HDMI make sure only the HDMI cable is connected when doing the above steps.
Hope this helps and thank you for using FixYa
Nov 14, 2010 | Sony Playstation 3 (PS3) Console
How do i properly connect my nintendo nes sytem to my direct tv. when i use the av cables i just get a blue screen. can u give me step by step to connect correctly.
Note: This type of connection is not possible with the newer-style NES.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Press the Power button in on the front of the NES.
Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Installation Steps:
Place the yellow end of the AV cable into the Video "in" on the back of the VCR. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
After system is connected to the VCR:
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Turn on the NES by pressing the Power button on the front of the Control Deck.
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen.
Recording Game Play
Set up the NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
Sep 06, 2010 | Nintendo NES Console
Ps3 wont display on the tv!!
Jun 10, 2010 | Sony PlayStation 3 40GB System
Was playing a ps2 game when the PS3 suddenly shut off. When I try to turn it back on by the back, the light turns red. As soon as i press the power button it beeps once, I hear a whir, then it powers off....
does the light blink red?
if so you have the TERRIBLE BLINKING LIGHT OFF DEATH
you have a few options:
1.call sony, send in your ps3, recieve a refurbished ps3 for $150
2.find a local to fix it for much cheaper
3.buy a new console
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
Ps3 broken
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360 freez crash problem unique
you should at least get the red lights of death. try holding in the sync button and press eject 4 times see if the lights change
Feb 24, 2009 | Microsoft Xbox 360 Console
Toshiba 50H81 50" Rear Projection Television Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
