Question about NexxTech 611-8212 Handheld Wet/Dry Vacuum
Low tire light stays lit.
I have a Buick 2000 Century. I had a flat and the low tire light came on. All the tires were replaced, but the light never went out. I had another flat a few years later, replaced 2 more tires, and the light is still lit. I wish it would burn out. I have to cover it with black tape to pass a safety inspection.
  • 114 Answers
If there is a red reset button in the fuse box, press & hold till your air pressure light flashes off....do this with the key on, engine off
Posted on Sep 15, 2009
Dyson dc25 vaccuum will not lie flat to go under low furniture.
Hi there, it's Jack at Dyson.
DC25's cleaner head is engineered with a low profile to clean under the edges of low furniture. However for cleaning under very low furniture we'd recommend using the onboard hose, wand and tools as the vacuum itself is not engineered to lie flat to the floor.
If you'd like some advice from our experts on getting the best out of your machine, please give us a call directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 11, 2014 | Dyson DC25 All Floors Bagless Upright...
My simer ace in the hole a5000 will not charge my 2.5 year old battery. The battery voltage reads 10.75 volts. I replaced the twelve volt charger and it originaly lit the yellow charging light , but it no...
I does sound like a controller issue. Try testing the charging output (be careful, who knows what the voltage may be coming out) I would say it is the battery but the yellow light thing has me thinking you are right. That thing has been sitting there maintaining the battery for 17 years, it is probably tired. The other bad news is if your battery has been sitting at that low volta.ge it may have a greatly reduced capacity now. Hope this helps some. .
Jun 09, 2011 | Vacuums
Very hard to push, the automatic height adjustment seems to be stuck in low postition
I'm growing tired of telling everyone what a piece of **** this vacuum is, I think you'll be the last! There is a design flaw that forces the wheels down according to how low you are holding the handle. Even when holding it at a normal operating height it is too low by design, causing difficult operation and finally multiple belt breaks! see my other posts about how to fix this, although it may not be worth your time!
Sep 22, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Electrolux 6500 SR
The cord light just indicates that the machine is plugged in and has power. In other words, you did great!
Nov 20, 2008 | Electrolux Epic 6500 Vacuum
Nu-tone 475 keeps running even without hose plugged in.
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. Once this is done, if the tank continues to run and cannot be turned off with the switch, then most likely the relay inside is defective and needs to be replaced (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected at the vacuum tank, it can be turned off with the internal switch, then either there is a short in the low-voltage wires, or else there is a hose still plugged into an inlet somewhere. ~ TTURAMBAR
Nov 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Embedded dirt finder light stuck
The Hoover uses a small microphone that is positioned in the plastic housing that the end of the hose fits into, just behind the bag compartment. What happens is that when dirt comes up the hose and hits the 90 degree corner, just before it enters the bag, the microphone picks up the sound and transmits that info to the electonics that controls the lights. Sometimes the microphone will stick and the red light will stay lit. If you take a screwdriver and give the microphone area a sharp tap with the handle of the screwdriver, this will often jar the microphone and it will begin working again. If not, it may need to be replaced. NOTE: this function does not affect the cleaning efficiency of the vacuum. Your vacuum will still work normally whether the dirt sensor is working or not. It is a totally unrelated function to the vacuum itself.
Dec 31, 2007 | Vacuums
Craftsman compressor
They put this under vacuums, relist it in the right place.
Dec 16, 2007 | Porter Cable 7812 Wet/Dry Vacuum
NexxTech 611-8212 Handheld Wet/Dry Vacuum Logo
52 people viewed this question
Top NexxTech Vacuums Experts
Are you a NexxTech Vacuum Expert? Answer questions, earn points and help others
