Question about GE GSS20IEP Side by Side Refrigerator
We have a side by side with water and ice maker in door the freezer side isnt making ice the icemaker is covered in ice i defrosted it and it is iced over again
  • 93 Answers
Your defost timer needs to be replace your fridge should defrost every 6 to 8 hours replace the timer cost about 20.00 thanks from gilles
Posted on Mar 15, 2009
Replaced the defrost heater,defrost thermostat,worked good for about 3
If the icemaker refill solenoid does not close properly or stays open too long excess water enters freezer compartment and that will freeze over the ice making machine plus other areas of freezer. There is an adjustment on the ice maker to regulate the amount of water going in - locate the screw (behind front panel of maker) and turn counter clockwise to lessen time of fill operation). Problem is not with the GE
Sep 06, 2017 | GE GSH25JFR Side by Side Refrigerator
KITCHENAID ICE MAKER STOPPED WORKING LED BLINKS WHEN FREEZER DOOR IS OPEN
Try firs unplugging power for 510 minutes, see if it reset.
Oct 10, 2008 | KitchenAid Refrigerators
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
I have a Maytag side by side refrigerator model PSD2450GRW. The ice maker will not make ice but the water comes out front just fine. The freezer works and the ice maker is at the ON position. Thanks for...
Hi and welcome to FixYa, I am Kelly. Usually when an ice maker slows or stops ice production it is a symptom of an aitomatic defrosting problem. The freezer must maintain 14 - 16 Deg F for the ice maker to make ice. Any temp above that an ice production stops. If the freezer is in the 14 - 16 deg F temp range then the problem can be the thermostat in the ice maker or the inlet water valve.
Here is simple test you can do at home to see if the inlet water valve is working:
1. Unlpug the unit for at least 10 minutes.
2. Remove the fiber board cover on the back of the unit.
3. Locate the inlet water valve and SWITCH the 2 connectors on the inler water valve.
4. Open the freezer door and hold the light switch button depressed. (or tape it down)
5. Take a glass and attempt to draw water through the door. Do this just long enout to realize water is going into the ice-maker.
^- NOTE the water will actually be going into the icemaker and the water valve is good!
If you have water going into the ice maker when you try water in door then the problem is either an automatic defrosting problem or an ice maker problem.
MAKE SURE TO RESTORE THE INLET WATER VALVE CONNECTORS to their original positons!
The ice maker can be tested using this link:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
If the icemaker checks out good then the freezer is too warm and there is some reasonthat the freezer is warming up. Usually this is caused one of the following:
1. Defrost control board. Item 13 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48135&diagram_id=28489467#d28489467
2. The defrost element and thermostat. Item 12 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48135&diagram_id=28489469#d28489469
The wiring diagram can be found here:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28489477&pkw_=basket&model_id=48135&NewWindow=1
Here is how I would approch troubleshooting on your unit:
1. Check out the icemaker using the american appliance link above.
2. Do a manual defrost by unplugging the unit and placeing a fan blowing into the freezer compartment for just over 2 hours. (Makes a water mess!)
3. Return the unit to normal service for a few days.
If it starts making ice..... you have an automatic defrost problem or... the evaporator fan is not running at full speed.
One last note... anytime you unplug the unit you must wait about 15 minutes for the cooling system to stabilze or the compressor will NOT start.
Thanks for choosing FixYa,
Kelly
Jan 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
Ice buildup from water feeding the ice maker
Are you certain that the ice build-up is actually originating from the water flow into the icemaker? If ice is built-up on the rear freezer panel, then your problem is more than likely a defrost component issue (defrost thermostat or defrost heater(s). If the ice is built-up on the side wall of the freezer near the icemaker, then water is probably being diverted inside the water inlet tubing that goes into the icemaker. This diversion is usually caused by an accumulation of ice inside the water inlet tubing. You will probably need to remove the icemaker in order to glance inside the water inlet tubing to see if ice is in fact inside the tubing. If so, take a screw driver or other object that won't puncture the tubing and remove the ice.
Contact an appliance service company if the ice is on the rear freezer panel.
Feb 17, 2010 | GE GSH25JFR Side by Side Refrigerator
Defrosted and now it won't make ice again
If the compressor or fan isnt running. Check your ejector blade in your icemaker.It should be at 12 oclock. If it isnt then remove the cover of the icemaker and turn the smaller gear counter clockwise until the ejector blade gets to the 12 oclock position. This should start the unit.
May 10, 2009 | U-Line Icemaker
FRIGIDAIRE SIDE BY SIDE FRS26LF8CSN ICEMAKER NOT DISPENSING WATER FOR ICE MAKER
alkimike;
I had a problem with my icemaker not drawing water or making ice, I did a full defrosting of my freezer taking everything out leaving the door open for about 1.5 hours It appeared that the inlet water supply had an ice blockace up in the water outlet, defrosting it cured the problem, it has been workinf fine for the last day tub is full of ice!!
Jan 28, 2009 | Frigidaire FRS266ZDSB Side by Side...
Fridge freezer door ice maker
the ice maker controls the seloniod the icemaker wire arm must be all the way down .just because the seloniod test good doesnt mean the valve seat isnt stuck the water valves open by your house water pressure if your filter is dirty this can also lower the pressure if the icemaker module is bad this also can cause it if you pull the front of the ice-maker off you will se a bunch of holes if you get a piece of 10 Gage house strip about 1/4 inch off either side and insert it into the holes marked t and h that will test cycle the ice maker they will be close together don't get shocked if the ice maker cycles and doesnt fill and the ice maker fill tube isn't frozen replace the water valve if the ice-maker doesn't cycle replace the brown motor module
Jan 09, 2008 | Jenn-Air JCD2389G Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Apr 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
GE GSS20IEP Side by Side Refrigerator Logo
119 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
