Question about Conexant CX11252-11 Modem
Red Blinking Light on My Modem
I got my AT&T High Speed Internet about three weeks ago. It worked for the first day and then the DSL/Internet lights on my modem started flashing red. Sometimes it will continually blink from red to green, or just stay red for a long time. After a day or two, everything will be back to normal and I can go online for a few hours. Then it goes back to blinking red. I unplug it and let it sit for a long time before plugging the modem back in and it turns on and starts flashing red again. When it does this, I can hear a clicking sound within the modem as if it's trying to connect over and over again, but fails anyway. I don't know if it's the modem or my phone line. I don't have an AT&T phone line, so I don't know if the lines in my apartment are faulty or if it's just the modem overheating or disagreeing with my computer. Any help would be great.
  • 1 more comment
  • Anonymous Jan 10, 2009
    thank you
  • Anonymous May 19, 2009
    I have the same problem, I got a new computer and it never did this with old one, almost all time, get red light and disconnected, unplug modem and replug then back in for a few, then red again, very aggravating. called ATT, they checked line said was ok, does modem need to be replaced anyone know
  • sleeknight May 19, 2009
    I have same problem, am with ATT, called att they checked line said was ok. Doesn't happen all time, but just occasionally - just goes red blinking and have to unplug and replug - very aggravating. Do modems need to be replaced or does anyone have any ideas why. I bought new computer, never happened on old one.
Benimur
  • 6966 Answers
SOURCE: need download cd for modem/soundcard
Hi, You can try & proceed to HP website (http://www.hp.com/) and go to the Software & Driver Downloads (left side near the bottom). You have to determine the specif model/version of your HP computer which might look something like "HP Pavilion 4550Z" From initial indications you would be looking for an Internal Modem/Sound Card that was originally set for Windows 98SE. Chances are that it is a Conexant or Rockwell SoftK56 Data,Fax PCI Modem, with Master Riptide PCI Audio Device. Post back should you need additional information. State your PC's model. Good luck and kind regards.
Posted on Oct 08, 2007
SOURCE: Computer cant connect to internet
set up a new internet connection and configure the modem which yuou are having
Posted on Feb 08, 2008
SOURCE: password on wireless
how to change my password dsl internet
Posted on Aug 16, 2010
Panth3on
  • 71 Answers
SOURCE: Connect 2 PCs to Westell 6100 DSL modem
well depends on if you want to hookup wirelessly with one or not. If the modem has a USB connection as well as ethernet, then you can hook up 1 computer to usb and 1 to ethernet with no problems. If you do want a wireless hookup then yes, you need a wireless router. I would just go with a router because of the convenience of being able to go wireless if you decide to. I would suggest a Linksys WRT-54GL with a 3rd party firmware (DD,-WRT, Tomato, etc.) Hope this helps.
Posted on Sep 14, 2007
SOURCE: conexant data fax modem
preciso driver modem 56k pci v92 ami_cw
Posted on Aug 01, 2008
2wire Modem blinking red dsl light problems. Tech came out and check out phone line, tried his own Ethernet router and still got the blinking red under DSL. Tech order for a port change on att company...
if the speed was upgraded to ADSL 2 you need ADSL filters that match this. Check the model number of the ADSL filters and check the type of DSL is compatible with the Speed change.
Apr 11, 2017 | 2wire (1000-000057-000) Modem
Dsl light goes beyween blinking green, then goes solid red, then back to blinking green. Cannot connect to internet anymore.
The modem cannot get a signal from your service provider. The DSL light is an indicator if your modem is communicating with the network of your service provider. DSL light should always stay solid green. Try contacting your service provider. It might also be an indication of a bad modem.
Aug 31, 2011 | Arris 221002 DSL Modem Southwest Region...
My dsl light on my 2wire gateway has been blinking red for an hour, it is past the service activation time and everything is set up correctly but it won't work!
did you install all the filters on all of your phone jacks?
If so then power cycle the modem "unplug it from the ac for 2-3 minutes". Try again
If still no luck open a trouble ticket with att and tell them its not connecting on the DSL side..
Aug 04, 2010 | AT&T High Speed DSL Modem
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
Jan 28, 2010 | AT&T High Speed DSL Modem
Westall modem taking 5 min to connect to internet to (AT&T DSL)
its your connection which is the problem plz try complaining on help line of you connection
Aug 27, 2009 | AT&T High Speed DSL Modem
Westell 6110, No internet light.
Contact verizon if they can replace the router becase the internet light should be green and flashing as you use the internet.
Dec 30, 2008 | Westell Wirespeed VersaLink...
Conexant CX11252-11 Modem Logo
2,930 people viewed this question
Top Conexant Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jessi Singh
Level 1 Expert
Are you a Conexant Computer and Internet Expert? Answer questions, earn points and help others
