Question about JBL Audio Players & Recorders
How to connect sub to Amp JBL JSR 635i
I am unable to connect the sub of JBL JSR 635i to its amplifier. tried several ways but aint working.
2 Suggested Answers
SOURCE: jbl subwoofer
i have an jbl acr 10 sub, which blowes the 0.62 sb fues instantly. Could it possibly be the pair of 3300uf @ 50v gone bad?
Posted on Sep 04, 2008
Why does my inline fuses keep blowing on a jbl gto 14001 amp
You need to calculate the amount of amps being driven through that fuse + the amount you need to feed the amplifier.
In my Volvo S40 and V70 I had no problems driving an amplifier of the rear power connector, but on my Honda S2000 however I had to create a different connection all the way to the battery line for a smaller amp (connection as in cables, condensers/filters and fuses).
Feb 18, 2016 | JBL Car Audio & Video
I have buy JBL four way channel amplifier 3 months before. Nearly 2 times my amplifier is not working. Red light is glowing even wen ma car is in off conditions and amplifier is not working. help me
Hi, Looks your amp has gone into "protect" mode, the first thing I would check is the fuse, should be under the bonnet (hood) about 15 cm's (6" or so) from the battery. I've found a couple of sites that may be able to help with your problem.
1. > How to Troubleshoot Dead Sub Amplifier Car Audio
2. > Amp in Protection Troubleshooting
Trust this helps, regards Alan.
Apr 12, 2015 | JBL Car Audio & Video
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Bridging outputs on JBL BP300
Hello paulnkate,
The BP300.1 is a mono (1 channel) amp. You cannot bridge a mono amp. Bridging is a method of combining the outputs of 2 or more channels of a multichannel amp into a single mono load. On your amp you would connect a single sub to one of the +'s and one of the -'s (either one is OK, they are connected internally). The other pair of terminals is just for convenience, making it easier to connect, if you want to power 2 subs.
Hope this helps.
Jul 20, 2009 | JBL BP300.1 PowerValve Series Car Audio...
Using JBL 4410 3-Way crossover, trying to use PG 12" Dual 4-ohm
ok, connect the amp positive to the positive end of one sub coil, take the negative of that coil, and run it to the positive of the second sub coil, then run the negative out of the second sub coil to the negative of the amp.
Mar 29, 2009 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Can this amp run two subs off it?
heck ya there are many different ways to hook that amp up if u have any questions on how to wire your speakers go to www.avatarspeakers.com/wiring.
Feb 19, 2009 | JBL BP1200.1 Car Audio Amplifier
Jbl amp kiskcs in and out
Something inside the amp is busted.... stop hitting it... and replace it.
May 18, 2008 | JBL BP1200.1 Car Audio Amplifier
JBL Sub Amp Wiring Please
it seems rather redundant to bridge a mono amp. Unless the instruction manual states otherwise, i would assume that one speaker output is identical to the other (ran in parallel, like an A or B speaker, not like Left or Right), and you would present the amp with a two ohm load by wiring one speaker to each output. Bridging it may or may not work, but, again, it just seems redundant.
Mar 01, 2008 | Car Audio & Video
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
609 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
