Question about HP DeskJet 920c InkJet Printer
HP deskjet 920 c crooked feed
Each time my HP deskjet feeds in a new sheet to print, it goes in crooked and srunches up, then jams. How do I fix this? Many thanks for help!
  • Adam Turner Jun 04, 2007
    There was a small piece of paper jammed at the back. Thanks.
    President:
  • 2,961 Answers
There should be a rear panel to remove and check to see if there is any small peices of paper caught in the rollers or obstructing one side, if not the grip on the the roller is worn or the paper aligning bar is open too wide and allowing the paper to tilt. This is a more common problem with shiny surfaced paper, so try a more matt rougher quality paper.
Posted on Jun 04, 2007
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Envelopes jam in my hp 6940; paper sheets feed fine
I have had varying success with envelopes. Can you feed in the other way round? Sometimes different envelopes perform better. The peel N seal can be very difficult
Apr 10, 2009 | HP Deskjet 6940 InkJet Printer
I had a paper jam, and now every time i try to print it jams the ink cartrages , one paper jam and now it will not work
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 28, 2009 | HP Deskjet 5440 InkJet Photo Printer
I need help repairing my HP Deskjet 5110xi all-in-one
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 10, 2009 | HP OfficeJet 5110 All-In-One InkJet...
Hp deskjet f380 paper jam
Jan 07, 2009 | HP DeskJet F380 All-In-One Printer
Printer feeds in 2 or 3 sheets of paper at a time and then jams
Dears eveenz,
It seems that paper feed roller of your printer is broken. This part is integrated in drive assy. You need to replace drive assy of the printer in order to feed the paper properly. I plan to discuss this topic at Inkjet Printer Forum since I cannot post image more than 150 kb here. Explanation with image will make you know more easily. Please send me your mail to ijxpert@gmail.com so I can contact you as soon as I finish my post there.
Please rate me when you find this answer be useful for you
Regards,
Nov 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Paper Jam on
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Crooked printing on HP C3180
good paper also try instalinga fresh new driver from website and unstall old one 1st before u install new one maby try runing cc cleaner also free tool u can dl online free form filehippo.com
Jan 07, 2008 | HP Photosmart C3180 All-In-One InkJet...
Missing Tool box software for HP Deskjet 690C
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=58156&lang=en& Check the paper feed area for loose debris or a stuck piece of paper. Good Luck, Tim
Feb 10, 2007 | HP DeskJet 690c InkJet Printer
HP DeskJet 920c InkJet Printer Logo
192 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
