Question about HP Compaq Presario V2010US PC Notebook
Hp v2010us screen is almost black, but i can see extremely dim
...dim images. contrast keys don't do anything. I would like to remove the cover near top of keys by the hinges to see if there are any loose connections. or do you think this is a problem with screen
  • 28 Answers
I have fixed a few laptop screens with this problem ...it is usually the lcd inverter ...somtimes if you just unplug and plug back in it may work , but usually a new one is in order .....The inverter is a small cuircut board just behind the plastic cover at the bottom of the lcd screen ....to get to it you probly need to remove the rubber protectors around the face of the screen and there are screws behind them ....not sure about your model but maby do a search for replacing the screen on it and you will get pictures that show you how to take it apart.
Hope this helps
Terry
Posted on Jan 09, 2009
I just had my Emachines D520 laptop display replaced because it was cracked. The new display is too bright, and the Fn keys that are supposed to control brightness don't work properly. When I use these...
Try going to control panel, then device manager, and try right clicking and updating all drivers that have to do with graphics or your screen. If this doesn't do the trick then try finding the display drivers manually.
Aug 24, 2011 | Acer Computers & Internet
How do I turn up the brightness on a HP Probook 6550b?
PLEASE RATE ME!
go to the search icon under start. search brightness. it will tell you step by step what to do.
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
May 09, 2011 | HEWLETT-PACKARD HP ProBook 6550b Notebook
I have new batteries in it and the screen is still extremely dim and sometimes won't even turn on.
Try adjusting the screen contrast. Press and hold the ON key and press the + key to increase the contrast. If you go too far, repeat the process with the ON and - keys.
Nov 27, 2010 | HP 10bII Calculator
Need help with a Benq PB6100 projector. The image is partial bright and clear, partially dim.
1st you have to connect your cables correctly, than set up your contrast in 50 if your contrast is in lower level, than adjust the sharpen and brightness with perfect adjustment remember do not place it near a woofer or speaker
For reminding me : trimoxibit@live.com dim
Jun 21, 2009 | BenQ PB6100 Multimedia Projector
My laptop will, once in a while (every couple months), have3 "issues" with its brightness/contrast. If I leave the brightness alone, it will turn most of the screen red. If I lighten the brightness AND the...
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 14, 2009 | Gateway M320X Notebook
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Can not see anything on the screen
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Mar 28, 2009 | HP Pavilion dv9700t Notebook PC
HP dv9000 won't come out of black screen.
You could have a faulty video card, or a faulty inverter, (this supplies high voltage to the CCFL lamp), or a faulty CCFL lamp.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 19, 2009 | HP Pavilion dv6000z Notebook
Ti84 plus, screen problem
  1. Press and release the gold [2nd] button. Verify that the blinking up arrow appears in the display.
  2. Press and hold the blue up or down arrow key to increase or decrease contrast, until the display is to your liking. Be alert: the display will change quickly.
The calculator will remember your contrast setting; you don’t have to adjust it every time you turn the calculator on.
Mar 10, 2008 | Texas Instruments TI-84 Plus Calculator
HP Compaq Presario V2010US PC Notebook Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
