Question about Saeco Vienna Espresso Machine
Grind is too coarse and "pucks" are wet and fall apart.
I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper. The coffee "puck" comes out wet and mushy. I use several Saeco Viennas at various locations and this particular one makes much more noise during its pumping cycle. Dswish
  • 29 Answers
You say " I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper" By making it more coarse you are making it weaker. Unless you just wrote it wrong. To make it stronger you should lower the grinder number to a smaller number. Usually about 4-6. Be sure you have the grinder grinding when you move it to a lower number. The pump noise could be that in shipping your pump came loose from it's mount. Nothing you can do without sending it to a Authorized Saeco Repair shop.
Posted on Jul 29, 2007
I have turned the grind knob all the way down, below 1.
Sounds like there is not enough coffee to make a solid puck. If you get crema, grind coarseness sounds ok. A finer grind will produce less coffee grounds for the puck and increases chance of clogging.
You may have to balance grind size with amount of crema to get solid puck.
Big problem with these is you want dark roast for espresso, but oil on beans clogs grinder. Are you using a dark roast? A medium roast works better in these. Or, can you increase the grind time? My Super-auto had a program option to increase time. But not in reg instructions. Got it from authorized repair facility.
May 04, 2016 | Saeco Vienna SuperAutomatica Coffee...
There is a excessive amount of water collecting in the drip pan, and I need to empty the pan every other day. Before it was once every two weeks or so. I have taken the "unit" apart to clean the...
Hi
Excess water going into the drip tray is usually an indication of the grind being to coarse. If your pucks are not solid but just fall apart this is the case. When the grinder is grinding, turn the big knob in the bean hopper down 2 numbers smaller and see if this changed. If you have a second knob in the bean hopper change the to the plus side, but not all the way to the plus. Do this first before you change the grind setting. Excess air between the grind allows more water in the brew unit and when it is done it goes into the drip tray.
Mar 23, 2011 | Solis Master 5000 Espresso Machine
Pucks in dregs drawer very wet
Hi
3 things can cause wet grounds.
1. You don't have enough coffee going into the brew unit. There is a lever on the right side behind the door at the top. Push it back towards the rear but not all the way. This will put more coffee in the brew unit and take up the air space so you will have less water.
2. Your grind is too coarse. Pull the lever below the bean hopper towards the front when it is grinding, to make the grinds smaller. Again less air space. Do this 1 number at a time so you dont make it too fine. Let each adjustment for 3 coffees before you make the next adjustment.
3. Your grinder has come apart and is grinding very coarse (French press). New grinder.
Dec 28, 2010 | Saeco Magic Comfort Plus Espresso Machine
My coffee is weak. i have played with the grinder, placing it at different no. on the outside plus i have played with adjustment on the interior.
Hi
Check the grinds. If they are coarse you have a separated grinder. It usually means it needs to be replaced I have seen them on ebay, but if you can't find them, I have some. If they are not coarse, you have to make 3 coffees before the grind will take affect. After you change the grind you have to make 3 drinks before you will see a change. If you don't have a puck in your dredge drawer, you don't have enough coffee going into the brew unit. Push the lever behind the door in the center top back to the +, then forward 1 click, and try that. There should be a full puck going into the dredge drawer that has the consistency of coarse sugar. If it very coarse its the grinder.
Dec 12, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco taleo grounds are very wet - almost fluid! this hase started recently when i changed my beans. i have changed the grind to course but with no effect. any ideas?
Try adjusting the amount of coffee and then the grind to finer. If there is not enough coffee in the chamber then it gets over extracted and you get a soupy puck at discharge, if the grind is too coarse, you might also get the same result. Think of your coffee grind as rocks and sand and that will give you a better feel for the proper setting for your machine.
Jan 29, 2010 | Saeco Talea Touch 14-Cup Coffee Maker
Hi, I have a Miele 4070 that I bought 3 months ago. It made great coffee for the first two months and then the coffee suddenly became weaker, and thinner and has less body. I have not changed beans, and...
,Hi
If you have adjustments for your bean hopper, 1 should have a + and - on it. Move that adjustment to the + but then back it up 1 click. Then go to the grind adjustment and move it down to a smaller #, but only when it is grinding. When you get the grind adjusted you should have grinds that look like coarse granulated sugar.
If you have taken the brew head apart you may have put it together wrong.
Jan 05, 2010 | Miele CVA615 Espresso Machine
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
Waret Pucks
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Jun 03, 2009 | Saeco Royal Professional Espresso Machine
Why are my ejected coffee pucks very wet? Seems
You need to be sure the removeable grinding surface is clean and not clogged. If it is not clean, water has problems passing through the screen and the water cannot escape, staying in the puck...
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Espresso Machine Logo
1,931 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
