Question about Dell 3000cn Color Laser Printer
Won't recognize paper is loaded
Dell 3000cn will not print. Keeps asking for paper reload. I've turned machine off and on, opened and closed all doors, reloaded and unloaded paper....still won't recognize paper is in machine and won't print.
Changed code for type of paper.
Posted on Jan 10, 2009
I have a Dell 3000cn printer it is saying load paper but the paper is loaded but wont print
check whether the cartage is fix well or the paper is far from the area from where the printer starts printing.
Jan 27, 2011 | Dell 3000cn Laser Printer
Dell 3000cn error message
does that message appears in the printer on the PC?
if its in the pc, try reinstalling the printer...
firts uninstall it from control panel>printer and faxes, and delete it by clicking it and pressing delete.. after you see the icon does not appear anymore, reboot..
then reinstall everything back again, and when you reinstall everything, make sure everything is well connected, and the printer on....
Dec 13, 2007 | Dell 3000cn Color Laser Printer
I have the Dell laser printer 3000cn. The printer powers on and everything but I can not do anything because it keeps asking me to close the reg cover. ther reg cover and all the other covers on the...
Dell 3000cn Color Laser has a duplex. If you face the printer on the top right of the duplex there is a button to release the duplex and it folds back. The reg cover is a door on the back of the printer that is covered by the duplex, try opening again, I know you have done this, maybe even wiggle it a little see if it registers as closed.
Also check to see if any dust or paper pieces maybe be jammed in there.
Nov 02, 2010 | Dell 3000cn Laser Printer
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Aug 06, 2009 | Dell 3000cn Laser Printer
Printer does not recognize that there is paper in the tray
Using the printer panel; you need to change tray paper size from a4 to letter or the size you are using to print on.
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
An astrick will appear to the right of the size paper that the printer currently has selected.
Apr 03, 2009 | Dell 3000cn Laser Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Dell 3000cn
if the printer is setup for A4 paper , it maybe that your p/c prog is trying to print using letter size.
microsoft tends to default to US sizes wjich are letter.
if using word check page setup for paper size
May 20, 2008 | Dell 3000cn Laser Printer
Dell 3000cn Color Laser Printer Logo
248 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
