Question about Toro Lawn Mower With Toro Power Tools
Toro mower with clogged fuel line
I was told my Toro mower's fuel line is clogged. It will run, start to sputter, then quit. You can pump the bulb and start it back up then it does the same again. I just had it serviced and this started the second time I used it afterward. I have not unscrewed the cover yet, and before I do, I would like to know what I should be looking for and is it as simple as just slipping it off of a nipple type thing and pouring clean gas through it?
    Scholar:
  • 76 Answers
That doesn't sound like a clogged fuel line, it sounds like your carb either needs a cleaning or a rebuild. If your fuel line was clogged than you wouldn't be getting fuel to the carb and you wouldn't be able to prime it. First check the smell of your fuel, if it smells stale then you sould empty it out and put fresh fuel in.Next take the air filter housing off unless the carb is exposed enough to get to easily. If you clamp off your fuel line (unless you have a shut off) so no fuel passes to the carb., wipe down or with an air hose blow off the bowl of the carb so there is no debris, pull the screw out of the bottom of the car., be sure to use a clean container to catch the fuel and look for any debris in the fuel. You can also take the bowl off and see what the inside of the bottom of the bowl looks like. Your looking for any debris or gelling of the fuel inside of the carb. if anything is noticed then the carb. is going to need atleast a cleaning. If a cleaning doesn't work then you may need a rebuild kit. Any qeustions on any of this please feel free to ask me.
Posted on Jan 11, 2009
  • camxposure Oct 07, 2011
    long way from an easy repair
The problem is the line itself- it rots.... you will probably notice the where the gas tank and fuel line joined [gasket] you get exposure deterioration from the mixture of air and the decay from gas - it will become brittle- and it will flow fine with the pressure from the bulb- but it won't draw gas into the carb from the low pressure vacuum leak- replace the hose- and choose a higher quality chemical resistant as well as gas resistant - keep enough to last you several seasons- empty the gas out as frequent as possible- best to only put in enough for the job- filling each time
Posted on Oct 07, 2011
    the problem is the line itself- it rots.... you will probably notice the where the gas tank and fuel line joined [gasket] you get exposure deterioration from the mixture of air and the decay from gas - it will become brittle- and it will flow fine with the pressure from the bulb- but it won't draw gas into the carb from the low pressure vacuum leak- replace the hose- and choose a higher quality chemical resistant as well as gas resistant - keep enough to last you several seasons- empty the gas out as frequent as possible- best to only put in enough for the job- filling each time
Try the easy stuff first. See if it runs without the filter if so then replace the filter. Replace the primer bulb even if it seems OK. Then get into the carb stuff from trippssmengi.
Posted on Jan 26, 2010
  • smtalati
    smtalati Oct 21, 2012
    what is the primer bulb, mine starts and then stops. i took out the filter , same thing. i think it is the dirt in the link or carb or tank bottom. what should i do
Engine starts after primer bulb is pressed 5 or 6 times, but dies after running a few seconds.
Main jet in carb is clogged. Also check the fuel lines to carb and make sure that they are intact and have no leaks.
Jul 29, 2016 | Toro Recycler 22" 149cc Personal Pace Lawn...
Fuel pump will not work on toro 50 inch zero turn
How did you check it? Disconnect the fuel line at the carburetor and put it down into a bucket. Hold it there and try starting the engine. If it pumps out its good and if not it could be a clogged fuel line coming from the tank to the fuel filter and then to the pumpYou may have a clogged fuel filter also. Fuel pump works off of the pulsar tube which creates a vacuum which in turns pulls on the diaphram of the fuel pump and causes it to pull fuel from the tank and push it to the carburetor.
Sep 18, 2013 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
May 16, 2011 | Toro Garden
Toro mower quick running after 5 minutes - repair shop said cleaned carb jets, air filter, plug - same thing next time I ran it - repair shop then said it was probably the fuel cap vent. Just run it for...
Hi and welcome to FixYa. First off having worked in lawn mower shops personally you should take your mower back to the shop you had it repaired in. What you have is what we in the biz call a repeat disrepancy. Most likely there is a fuel supply problem if the jects have been cleaned. The problem can be:
1. Debris in the bottom of the fuel tank.
2. Clogged fuel filter
3. Float needle and seat is not opening fully or there is debris in the needle seat.
4. Clogged or pinched fuel supply line.
That is about it but I am telling you the repair shop owes you a free labor fix for this. You may have to purchase a needle and seat for around $5 - $6.00 and or the cost of a new fuel filter but, they certainly should eat the labor.
Thanks for choosing FixYa.
Kelly
Sep 18, 2010 | Toro Lawn Mower With Toro Power Tools
Mower wont stay run n unless i hold primer in
If it is a float bowl carburetor may have a jet clogged or the primer bulb could have a hole in it. If it is a diaphragm type carburetor, the diaphragm may be stiff and needs replacing. Check it out.
Good day.
Nov 07, 2009 | Toro Garden
1974 Johnson 70 hp outboard, quits on acceleration.
It sounds like your motor is starving for fuel. At an idle, you have adequate flow to keep the engine running. When you call for more fuel...you sputter and quit. Could be a clogged filter or trash in the line or in a jet. Yes you will have some air in the bulb, but not a great deal. You could be sucking air at a hose connection (loosing some prime)...try this, start the engine and slowly accererate, have someone pump the bulb as you accelerate, see if the engine works properly while doing this test.
Aug 27, 2009 | RTO Oar Sockets
Mower runs good for fifteen minutes then the
Mine did this too. THe semi-transparent fuel filter will look like no gas is in it if you have the problem I had. The gas cap on the tank has a tiny breather hole to keep it from coming under a vacuum as gas runs out. Push thru it with a toothpick to clear the hole. That's all it was. But I did have some black debris clogging the filter and had same symptom.
Aug 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
May 01, 2009 | Toro Lawn Mower With Toro Power Tools
Toro TimeCutter z4200 will not start
First check to see if there is a fuel shutoff under the tank. On some models there is a fuel filter screen inside the tank where the fuel line connects to the tank. If niether of these work, R&R the carb.
Apr 08, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
3,099 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
