Question about Epson Stylus C86 InkJet Printer
Cannot fax using epson bx300f - Epson Stylus C86 InkJet Printer
  • 1 more comment
  • stretchyd Feb 01, 2009
    I can receive faxes but for some reason cannot send them. I have BT Broadband and my phone is connected to the phone line through an adapter. Is this the problem? The instructions say I should have a DSL Filter, but I thought the adapter i had was!
    I'm in a muddle
  • mcfax Feb 17, 2009
    same problem.
    add: printer is not able to make adifference between call and fax.
  • stretchyd Mar 29, 2009
    Hi gwbm
    Thank you for your response.
    Are you saying I do not have Broadband as I thought I did, especially as I am paying for it! There was no internet connection in this property when I moved in, so as far as I am aware there is no 'Dial-up'.
    I am probably being an idiot with the above, but I am a computer muppet!
    Cheers
  • 353 Answers
This response is a little late, but it's because you all appear to have something other than an Epson C86, under which your problems are listed! Eoromarts problem is super-generic. It could be due to hundreds of reasons ranging from "because I was in Blackpool at the time" to "my wife had borrowed the modem cable for a washing line". Come on, you need to give a lot more information than that!. McFax - your problem is simply not understandable please be much more specific!.
However, we may be able to help Stretchyd who has provided actual information on his problem. You cannot send faxes by Broadband. You need a good old-fashioned dial-up modem (which we all used to use to connect to the internet before broadband). You clearly have one of these, otherwise you wouldn't be able to receive faxes.
So you should have a cable from your Broadband modem to the phone line, going into the broadband (DSL) filter ADSL port. You should also have a cable running from your dial-up modem socket into the broadband filter phone port (you may also have a phone going into this, so you will need a phone socket doubler to take the phone wire and the dial-up modem wire).
So, to send a Fax, you need to run your Fax program (usually the Windows XP fax module) and set up your system for dialling out. If you need help with this post a new connebt.
Posted on Mar 28, 2009
HI We cannont receive incoming faxes, however we can send out so no problem with our phone line. The model is BX300F
make sure your mulfuntion printer fax setting is correct, check setting menu maybe it is not configure correctly
Feb 15, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson BX300F display shows priner error see documentation
Epson BX300F display shows priner error see...please help my
Dec 19, 2010 | Epson Stylus Multifunction Printer/...
My BX300F Stylus printer? I do not know how to use, turn on recieve or send faxes? from a dippy granmother, thank you
hello Spanish Lady
Epson USA and canada do not have any information about this item, although i found a link (guide /manual HOW TO SET UP) the printer
ftp://download.epson-europe.com/pub/download/3216/epson321657eu.pdf
and then there are videos available -- possibly how to use this
http://www.youtube.com/watch?v=VEOxCYLrvsg
i hope i was able to help you
God's speed !
Nov 09, 2010 | Epson Office Equipment & Supplies
We have epson bx300f, changed rooms and now have to sit and press buttons on machine to receive faxes where before they would come through automatically. How do I revert back to that setting?
Had a quick look and found that you may have turned off the auto-answer mode.
The way to set it back up is provided on page 5 of this manual:
ftp://download.epson-europe.com/pub/download/3217/epson321754eu.pdf
  1. Press Mode [Copy/Fax] to select Fax mode
  2. Press the up/down arrows to select "5.Fax Settings" then press OK
  3. Use the up/down arrows to select "5.Communication" then press OK
  4. Use the up/down arrows to select "4.Rings to Answer" then OK
  5. Use the up/down arrows to set the number of rings then (yep, you guessed it!) press OK
  6. Press the button for "Auto Answer/Space" (looks like a phone handset with the work "AUTO" next to it) to turn on Auto Answer Mode.
  7. Press OK (for the 4 millionth time it seems!)
  8. Finally, press "Menu" to return to the first screen in Fax mode.
Hopefully that will resolve your problem :)
Mar 25, 2010 | Epson Stylus Multifunction Printer/...
My Epson bx300f cannot send faxes, just says no dial tone?!!!
ALL fax machines are ANALOG devices and will not work on a DIGITAL PHONE LINE.
Jul 06, 2009 | Epson Stylus Multifunction Printer/...
Epson Stylus C86 InkJet Printer Logo
833 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
