Question about NEC DTH-8D-1 Corded Phone
Recall last phone call to see number
Have NEC-DTH-8D-1 phone, new working with this phone. Needs to recaal last phonecaal to view number to return call
  • Eric Conrad May 11, 2010
    Please press , then dial 3 (with phone idle). This will reveal the software for your system which will help determine the answer. This phone is used on two different systems. Let me know.
    Problem Solver:
  • 14 Answers
Press "Redial" then *(star). The redial key is a multifunction key. You can either use redial or utilize the phone system speed dial directory.
Posted on Nov 11, 2009
I have a NEC DTH-8D-1 Corded phone. I moved my desk and plugged the phone in at a different phone line port and the screen now reads "Initialize." What is it asking for? How do I set up my phone at th
Your extension is hardwired to 1 jack, if you plug in somewhere else you'll be lucky if the jack is active with another extension. Someone needs to re-wire your extension in the phone room to your new jack. If it won't activate but says Initialize, then that jack probably has a live fax line or analog extension, but not a digital line that works on your phone.
Sep 02, 2014 | NEC DTH-8D-1 Corded Phone
How to change name display
There is no user programmable way to change the name display on your phone. On NEC systems, you have to go into programming mode and access the memory block for extension names. Sorry.
Jun 01, 2011 | NEC DTH-8D-1 Corded Phone
The speaker phone will not work
If you have the speakerphone option enabled in system programming, you may just have the mic turned off. Try pressing Feature then 1 while the phone is idle. The mic light should light up if it wasn't already lit.
Apr 13, 2011 | NEC DTH-8D-1 Corded Phone
FEATURE BUTTON IS STUCK ON, MUST PUSH ANSWER BUTTON TO ANSWER PHONE CALLS.
with this nec phone. you need to unplug it all . stick a small screwdriver on the feature button to pop it up and off the board (since its stuck) and plug it back in. to reset the phone.,
Mar 17, 2011 | NEC DTH-8D-1 Corded Phone
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
How do you change the time on a nec phones dth-8d-1(bk)tel
To Update Time: From operator telephone with receiver hung up; Press feature key; dial 9,#; enter hour and minute i.e. 0135; (press recall key to change from am to pm); press feature key to save and exit.
Mar 26, 2009 | NEC DTU 8D-2 Corded Phone
RECALLING PHONE NUMBERS
while talking on that line press line key again.
Feb 23, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Caller ID Scroll
Your system needs to have a mif-m card and kmm chip installed and all programming setup in order to scroll through the caller id. If this is all setup you can hit the directory button and than use the arrow buttons under the display to scroll. ldtsnj.com
Oct 30, 2008 | NEC DTU 8D-2 Corded Phone
Manual
It depends on what phone system you have but I assume you have an NEC Elite IPK 1:
NEC Elite IPK 1
or you can search their site at:
We Do Phones
Aug 08, 2008 | NEC DTH-8D-1 Corded Phone
NEC DTH-8D-1 Corded Phone Logo
1,314 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
