Question about Kenmore 62802 Electric Dryer
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
We have a Kenmore 90 Series Gas Dryer that will heat up, dry for about 10 mins then shuts itself off. If we wait about 30 mins. then we can start it up again. Seems to be overheating but cannot figure out how to check or what to check. As far as we can tell, outside vent is clear. Any suggestions? Thank you.
  • u8rcow Mar 07, 2012
    I have the exact same problem with my kenmore 90 series electric dryer. any solutions?
  • Anonymous Mar 12, 2014
    Model #110 79912990
    President:
  • 1,214 Answers
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Posted on Jan 19, 2009
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore series 80 heats and turns fine but stops after 30 minutes or so at any heat setting
Does it restart after it cools down? If so your motor may be overheating and shutting down.
Jun 20, 2012 | Kenmore series 70 80 90 Dryer Motor...
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Replaced heating element/worked for 10 min now doesnt
Howdy: Check the thermostat on the inside in the back. If unpluged or lint is clinging to it , the unit will shut off heat. Please inspect. Good luck - It also could be defective. - Doug
Dec 09, 2009 | Kenmore Dryers
Kenmore 90 series gas dryer
The trouble is actually with the start bearings in the drive motor,I bet you have a small hummmm or GRRRRR right at the start, as if the unit wants to hesitate.
Anytime you have a dryer that starts then shutsoff and must "cool" down, it is the motor.
Feb 18, 2009 | Kenmore Dryers
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Dryer won't dry
  1. thermostate 2 the gas valve cylanoids the 2 black things on top gas valve can be bad will heat then stop heating 4 awhile thay drop out dont open valve watch your valve listen 4 it if comes on run heat goes off dont come back on 4 awhile 3 5 min bad valve cylonoids
Dec 29, 2007 | Kenmore 64952 Electric Dryer
Kenmore 62802 Electric Dryer Logo
465 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
