Question about Panasonic KX-TG2631 Cordless Phone
Answer machine How do i change the amount of rings that before my phone switches to answer machine. Thanks Jason c
  • jason corlett Jun 04, 2007
    Thanks. First time on the web site but will be using it again
  • 883 Answers
If you see a "function" button on hand-held, then push it and scroll through all menu options to find "Initial set" then find "Answering" and push again to find "number of rings"
Posted on Jun 04, 2007
How do you change the amount of rings until the answering machine starts
Go to settings either handset or base station, look for ringing settings or answer phone, then you will see an option to change the ring count before the machine answers. You should also be able to look the manual up on the net. Can't be more specific as you have not stated the model, sorry.
Dec 13, 2014 | Lands Phones
Change from 3 ring answer to a 5 ring answer
The CS6119 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up.
If you have an answering machine connected, please refer to its documentation or else repost your question and specify the make and model of the answering machine.
Sep 03, 2012 | Lands Phones
How do i increase the length of ring time before it goes to answer machine?
Step 1: Determine the make and model of your phone/answering machine.
Step 2: Repost your question, being sure to include the information from Step 1.
Nov 10, 2011 | Lands Phones
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
Need more time to pick up phone(disabled)
The phone does not have this facillity.However,switching the answer machine "OFF" allows me to lengthen the ringtone to 16 rings as on the Users Guide.
Many thanks for your interest,
Dec 21, 2008 | Lands Phones
How can I change the Rings to Answer setting to one ring?
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1.
Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jul 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Feb 14, 2008 | Uniden Cordless Phone
Changing the amount of rings
Pick the phone up earlier it will stop ringing......:-)
To set the number of rings-to-answer
To set or change the number of rings-to-answer, use the following steps:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Fax setup, and then press tick
3. Use the < or the > button to select Fax Recv. setup, and then press tick
4. Use the < or the > button to select Rings to answer, and then press tick
5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press tick
But I still think picking up the phone earlier would be easier
Your Manual, please rate as fixya or post back
Dec 28, 2007 | Office Equipment & Supplies
Howto change ring times for audiovox answer machine
how can I set the proper day and time on my answering machine same as above Audiovox AXT847
Nov 29, 2007 | GE 29878GE1 Digital Answering Machine
Panasonic KX-TG2631 Cordless Phone Logo
147 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
