Question about GE WSM2700D Top Load Stacked Washer / Dryer
Ge stackable washer is off balance.
Appears to be sitting at an angle now. how do I remove the cover and level washer tub?
Krazytech
  • 725 Answers
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Posted on Dec 25, 2008
onthejob5130
  • 640 Answers
SOURCE: GE topload washer Agitator
theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Posted on Jan 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: i have a ge top load washer that the tub is off
Open the control panel to get the mini manual. It will show how to remove the front panel and check the tub supports.
Posted on Feb 15, 2010
mrbobfixit
  • 259 Answers
SOURCE: washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Posted on Jun 11, 2010
Testimonial: "Thank you MrBob. I will get the model number over the weekend. :)"
SOURCE: WCVH6800J1WW GE Washer error codes
need same solution, please post
Posted on Jul 30, 2010
How do you remove the cover for Cabrio Platinum Top Load Washer to see if clothes have gotten stuck between wall & basket of washer. I can not wash one load without getting the UL Off Balance Code!
it is extremely unlikely that clothes have got to the position you mentioned
unbalance comes from
1--- clothes out of balance in the tub--too much on one side
2--machine not level on the floor --- rubber feet missing from adjuster bolts
3-- suspension rods and insulators for the tub broken or missing
these suspension rubbers/ plastics break on a regular basis and allow the tub to sit at an unlevel state causing an unbalance situation when spinning
top covers are either held in place with screws at the front and back ( under plastic trim buttons ) or simply clip on to the side walls at the top
talk with a service agent as to how to remove the top or download a workshop manual for the machine from the net
Oct 29, 2016 | Whirlpool WTW6400SW Cabrio Washer
My GE stackable washer is pouring out water while filling up, when spinning makes horrible noise and tub goes crazy
The issue is that a shock or spring that balances the tub has come loose and pulled a hose off when it broke. So the shocks or the springs are bad. The hose might be able to just be put back on.
Feb 23, 2015 | General Electric GE 5.4 cu. ft. Large...
LG stackable off balance
Open the machine covers and check the tub/motor shock absorbers or dampers for condition. Best to change all if one is faulty.
Apr 11, 2014 | LG Front Load Washer & Electric Dryer...
Shaking GE Profile Washer
level the machine and make sure the floor is sturdy, you can even put a piece of plyboard under it.
Feb 05, 2014 | GE Profile WPRE6100G Top Load Washer
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Washer doesn't sit level in new laundry room
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
In order to check properly for internal issues,unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or rocking, is the floor on which the washer sits. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
May 23, 2010 | GE WSXH208A Front Load Washer
Tub rubbing at bottom
Could be as simple as the base pushed up in the center or a more complicated problem where the front apron is bent in which case you should call for service there is a fix for this
Feb 17, 2010 | Washing Machines
Washer makes loud vibrating noise when spinning. GE stackable washer dryer
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion........
Jul 19, 2009 | Washing Machines
Balancing problem Frigidaire stackable front load washer/dryer
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2009 | Kenmore 98702 Stacked Washer/Dryer
GE WSM2700D Top Load Stacked Washer / Dryer Logo
112 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
