Service Call 17H This pops up when I try to print multiple pages.
  • wolfgirl2 Jan 12, 2009
    Thank-You for your much needed help.
    Now what do I do to correct this problem?
    Guru:
  • 829 Answers
FATAL ERROR
CODE: 17H
SERVICE CALL 17
TONER RACK • If the toner cartridge does not rotate
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
Electrical components for detection of the malfunction
Rack motor (M2)
Rack clutch (CL1)
Rack home position sensor (PC4)
Master board (PWB-A)
Controller control board (PWB-P)
Step Remedy Reference
page
WARNING DIAGRAM
Control signal Location(electrical component)
1 Check PC4 operation. 149 PC4_ON 3-F
2 Check CL1 operation. 150 CL1_REM 2-F
3 Check M2 operation. 151 - 3-E
4 Replace PWB-A. - - -
hope this helps
Posted on Jan 09, 2009
20120122:
Each toner cartridge comes with it's own chip, so far correct.
The communication of this chip with the Master board (PWB-A)
and the Controller control board (PWB-P) is essential while initialising.
Those amongst us that have used refilled Tonercartridges should be
certain the Chip's counter has been reset indeed. That is a guarantee
your Cartridge-supplier should be able to provide.
When all cartridges are placed in the Drum and a visiual check shows no aligning mishaps ( e.g: cartridge not seated properly, sticking out in a 1 deg -off angle or: Drum not seated well, making it rotate a bit awkward ) the basic conditions for proper operations are available.
The only technical condition that has not been checked up to now is the condition of the contact-resistance: each Cartridge comes with a bunch of copper-coloured contacts, that provide means of communication with the Chip, means to get rid of Static-electricity and means to determine position. Whenever 17J pops up randomly,
the odds are that one of those contact-strips do not function well, jeopardising the MTBF of this otherwise beautiful device.
Solution: obtain the finest Scotch-brite or the fines Sand-paper you can
get and clean all of the contacts-surfaces. Don't be agressive on the surfaces, as they probably only are oxidised : as soon as that oxide-layer has been broken, your contacts are fails-proof again, providing you also have cleaned the "silver" colored SST contact-surfaces
of the drum. Use a Vacuum-cleaner and a soft brush to remove debris and waste-toner. Re-mount the Toner-cartridge in the only proper way
it should be mounted and move on to the next one. Don't forget to also clean the Drum by vacuumcleaner as this part is as important
as the cartridges itself if it comes down to the contact-surfaces.
Hope this helps, it did the trick for me !
Theo
Posted on Jan 22, 2013
Service Call: 17H Call Technical Support
refix ink cartridge and check there is not paper jam .
Apr 21, 2009 | Konica Minolta magicolor 2300DL Laser...
Printer only prints one page of multiple page document
i dont know how to conect lexmark printer X4250 to my computer
Dec 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Nov 26, 2008 | Kyocera FS-C5030N Led Printer
Where are the toner cartridges in magicolor 2300 dl
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17H
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing rack rotation
<Remedy>
Rack motor (M2)
Rack clutch (CL1)
Rather than try to explain in more detail i can forward you the service manual (4.17mb) if you update with an e mail address
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Printer is only printing one page of multiple pages i want printed. lexmark x5470
Make sure you have selected "Spool documents for printing" in the printer dialogue box that pops up after you give the print command. Depending upon the version of printer software you have, click on properties and you should find this option under one of the tabs.. (File > print)
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 03, 2008 | Office Equipment & Supplies
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Laser Jet 5550DTN printing problem
I am reading your question and coming up with 2 different thoughts.
Are you wanting multiple prints of one page, or are you wanting to print out a 5 or 10 page document?
I am not sure how to answer.
Feb 29, 2008 | HP LaserJet 5550dtn Printer
1,123 people viewed this question
jasbo
jasbo
