Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Forward fax to another fax line
I am trying to forward our faxes to another one of our offices, is there a way to set that up?
    Champion:
  • 320 Answers
IF BOTH MACHINES ARE ON THE SAME # IT WONT WORK, IF THE MACHINES EACH HAVE DIFFERENT # IT WILL WORK. JUSR FAX OUT NORMALLY BROTHER TECH
Posted on Jan 19, 2009
2 Suggested Answers
  • 16 Answers
SOURCE: our fax machine is out of toner in the office and
take out the drum and toner, look at the left and right sides of the drum and you will see a hole on each side the same size, about 1 cm diameter. place some black tape over one of the holes and give the toner a good shake, this will cheat the toner sensor into thinking it is full!! only do this in an emergency while you obtain a new toner though.
Posted on Aug 27, 2010
How to Forward this fax to another fax
try *21{other fax phone number}#
dial it into phone line when off hook
then #21# to turn off
Mar 07, 2018 | Toshiba E-Studio 170F Fax Machine
I want to forward my faxes from my Panasonic machine to another # temporarily.. is this possible and how?
Fax forwarding You might want to set up fax forwarding if you are going on a trip, but still want to receive your faxes while you are away. There are three fax forwarding settings:
  • Off (default)
  • Forward-When your All-In-One receives a fax, it holds it in memory and then sends it to the fax number that you designate.
  • Print and Forward-Your All-In-One forwards the fax to the designated fax number and prints the fax.
To set up fax forwarding:
  1. On the control panel, press Fax.
  2. Press Options until Fax Forward appears, and then press Select.
  3. Use the arrow buttons to scroll to the option that you prefer (Fax Forward or Print and Forward) appears, and then press Select.
  4. Enter the number that you want to forward the fax to, and then press Select.
Fwd now appears on the bottom left corner of the display.
Dec 16, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Our fax machine is out of toner in the office and
ask if your telephone company has autoforward features on your phone line, you can auto forward all incoming calls to another fax number. you can ask your telco for the codes to activate auto-call-forwarding.
Nov 03, 2009 | Brother FAX-8360P Plain Paper Laser
How to fax forward?
You can set your product to forward incoming faxes to another fax number. When the fax arrives at
your product, it is stored in memory. Then your product dials the fax number you have specified
and sends the fax. If it cannot forward a fax because of an error (for example, the number is busy)
and repeated attempts to redial are unsuccessful, your product will print the fax.
If the product runs out of memory while receiving a fax, it will terminate the incoming fax and only
forward the pages and partial pages already stored in memory.
When using this feature, the product must be the one receiving faxes (not the computer) and the
answer mode must be set to Automatic (see Changing how the product answers incoming faxes).
To use fax forwarding
Press menu/enter.
2 Use the < or > button to select Fax Setup and press menu/enter.
3 Use the < or > button to select Fax Recv. Setup and press menu/enter.
4 Use the < or > button to select Forward Fax and press menu/enter.
5 Press > to select On or Off and press menu/enter.
6 If you choose to turn fax forwarding on, use the alphanumeric buttons to enter the fax number
where you want the fax to go, and press menu/enter to save your selection.
Apr 15, 2009 | HP LaserJet 3330 All-In-One Printer
Norstar m7324 - forward to outside line
The solution for someone using the administrator phone (receptionist phone) is after discovering you have a fax call, depress the <link> button. Dial the fax number, wait for it to answer, then depress <link> again. This places call 1 with an outside number.
Apparently this is also available if you have a feature button by depressing <feature> <7> <1> instead of <link>. I haven't tried this so don't take my word for it.
This can also be used to forward a caller to an outside line, such as a cell phone. In the manufacturing business, our shop manager is never in the office. I may ask him if this is a viable solution.
Mar 23, 2009 | NorStar M7324 Telephone
Need to fax forward panasonic uf 895
Store the number in a one-touch area. example 15
name it FORWARDFAX
set
stop
Press 74 set
54
set
choose VALID
set
press one-touch number 15
faxes are now forwarded.
To unforward
press 74
set
54
choose INVALID
set
stop
Dec 18, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Panasonic UF-890
Take the swinging drum cover off of the toer cartridge and throw it away. It's only for shipping. They come loose and block the paper path.
Put the number you want to forward to in a one touch number position. (if you have to dial 9 for an outside line, be sure to put that into the one touch number also).
Function 74 set 54 set 2 for valid set stop.
Answer to last question, probably...not.
Aug 28, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Communication failure report
your machine has the capability to forward an incoming fax to a folder on a computer. If the faxes cannot "reach" the folder it will give you the message you described above. if you dont want ur faxes to forward you can shut this forwarding option off. Try going into user tools, interface settings
Aug 19, 2008 | Gestetner DSc525 All-In-One Laser Printer
Fax
I could guess it has nothing to do with the fax, but whats the chance someone has got "call foward" set on the phone line, in Oz its something like #21* to cancel, but check with your phone line provider in your country.. "how to turn off call forward".
If above is the case, line would forward to parish when fax is disconnect to phone line and fax number is dialed
Aug 02, 2008 | Brother MultiFunction Center MFC-440CN...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
