Question about GE GTS20ICNCC / GTS20ICNWW Top Freezer Refrigerator
Removal of the back panel in the freezer compartment
A repairman came to my home 2 times to unclog a drain hose and needed to remove the back panel in the refrigerator. There are no apparent clips or screws and is lost about getting this panel off and doesn't want to pry it off for fear of breaking it. It is a GE model GTS201CNCC. Any suggestions?
  • jedvic Jan 09, 2009
    These are not removable as they are one solid molded peice. Thanks
  • Anonymous Mar 24, 2014
    Is it a screw in bulb or a pin type?
    Sniper:
  • 51 Answers
Try removing the side and bottom panels to remove the back panel
Posted on Jan 09, 2009
Need help to unclog a drain on a GE Profile Bottom Freezer Refrigerator Model PFSS6PKW/PFSF6PKW. Specifically, where does the drain end? Behind the freezer & how to access it? Also found eroding t
You should be able to see where the drain tube comes out over the drain pan. Get some thin wire and run it down the tube and when it comes out in the drain pain, tie something onto it like a small piece of cloth and pull it back up through the drain tube to swab it out. The tape is no big issue, if you want to do something about the rust, there is a product that autoparts stores sell that turns rust into a hard, rigid metal. Or you can use a blow drier to make sure it is dried out and then spray rubber under coating on it.
Nov 18, 2013 | GE Refrigerators
Water dripping from freezer into refrigerator
Hi,Most likely the drain in the freezer is clogged up and frozen. Every time when your fridge automatically defrosting defrosted water dripping inside the fresh food compartment. You have to remove the back panel in the freezer and using a hair dryer defrost the drain which is located under the evaporator coil. Then put very hot water through the drain until it goes free.
Yes, you need to remove the back panel inside the freezer, It should have screws that come out then it should pull off and out.
On your model, the defrost drain hole/line is located inside of the freezer behind that back access panel, just remove that back panel, remove your freezer floor panel FIRST(Has 2 screws in front), that simply pulls out, then you will see the drain hole under the evaporator coil. It may be iced up, you will have to clear all of the ice and run hot water down the drain hole.
Once the back panel screws are removed that panel should just pull off, pull hard. Make sure your refrigerator is unplugged first.
Good luck.
May 28, 2011 | Kenmore Top Freezer Refrigerator
How do I access the drain tube to unclog it?
I have been able to gain access to it from the drain pan area under the unit then use my wet dry vacuum to **** the debris out of it. The rear has a panel you can normally unscrew to see it.
Apr 24, 2011 | Refrigerators
Liking water front door
You need to remove the panel inside the freezer compartment to access the evaporator rain line. Once accessed,you will see a drain hole. That drain has a hose leading to a pan in the back of the refrigerator; this drain is plugged an causing water from defrosting ice to drain to the pan in the back of the refrigerator. You need to unstopped that drain hose with compressed air and not chemical.
If you have any probem removed the panel inside the freezer, removed the cardboard panel to access the drain hose. Grab the hose and blow compressed air into it. Please note that you will be blowing back into the freezer compartment, and some cleaning will be necessary. The drain hole will then be opened.
Dec 16, 2010 | Hotpoint HSS25GFP Side by Side...
Water is draining into the refrigerator. It fills
Good day,
In the freezer if it has an ice maker, it will have to be removed.
Remove the back panel. Below the cooling coil is a drain pan.
It has a drain hole in it. If it is iced over you will have to defrost it, with the machine off.
Many use a hair dryer, but hot water with a turkey basting tool is
safer.
Once the drain hole is open, you will have to follow thru since the water drains into a cup in the fresh food compartment then thru the back wall into a drain hose on the rear.
Blockage can occur anywhere thru that area.
Service techs usually use compressed air with a hose to blow the lines clear.
If you have no access to something like that you wil have to get creative. Removing all the components and flushing them out is one option.
Aug 02, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
May 27, 2009 | Frigidaire 26.0 cu. ft. Side-By-Side...
Frozen water in bottom of freezer
Every ten to twelve hours your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-20oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
Apr 02, 2009 | Kenmore 62832 / 62834 / 62839 Bottom...
Lots of water in bottom of refrigerator
Every ten to twelve hours or more irregular intervals if equipped with an adaptive defrost control your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-25oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
Apr 02, 2009 | Estate TT14DKXKQ Top Freezer Refrigerator
The refrigerator is leaking water from the freezer.
First ask yourself how old is the freezer?
Does it need to be replaced?
May 12, 2017 | Kenmore Refrigerators
Remove the sheet metal panel from Whirlpool refridge
the rear panel is not removable. you need to clean the drain from inside the freezer compartment.
  • 1 remove food from freezer
  • 2 remove shelving and icemaker if equipped
  • 3 remover rear access cover in freezer usually 2 or 3 screw
  • 4 clean ice out from underneath the coil you will uncover the drain hole
  • 5 force hot water thru drain hole i use a turkey baster or large syringe
  • 6 reassemble in reverse order.
if you have any further questions please ask here and I'll be glad to assist any way I can. thanks Peyton
Mar 05, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Open Questions:
See all GE GTS20ICNCC / GTS20ICNWW Top Freezer Questions
GE GTS20ICNCC / GTS20ICNWW Top Freezer Refrigerator Logo
1,408 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
