Question about Dell Dimension E510 PC Desktop
Boot up problem
Have a Dell dimension e510, when starting up amber light is solid, no power from usb ports, or to monitor, computer light on mother board comes on fan comes on c drive lights up act likes it coming on. But still no green power light. Can anyone help figure this out can this be a mother board issue or pcu issue? Any trouble shooting ideas I can try? thank you for any suggestions.
  • johnbus28 Jan 09, 2009
    Thanks for your help, did what you said still not working. Soon as I turn on computer there is no blinking lights goes straight to solid amber. Very willing to try any other suggestions.
On my E510 the problem is the front I/O panel. To see if that is your problem unplug the power, pull the I/O panel cable from the motherboard (in front of the power supply next to the ram), pull the bios battery for 30 seconds. Put the battery back in and plug the power cord back in. It should start if the I/O panel is the problem. Here is Dell's part number for the assembly - "X8543 Front I/O and Control Panel Assembly". Until you replace it you will have to remove the bios battery every time you turn it off to get it to start again. Rebooting it is not affacted.
Posted on Jan 11, 2009
  • 26 Answers
Try another monitor - it could be faulty...
Posted on Jan 09, 2009
  • Diana Umukoro Jan 09, 2009
    Hi there
    Well if a good monitor still doesn't get a signal, I think it's the graphics card in the PC. I suggest you take it to a shop where they can test it with another graphics card, before they sell you a replacement one.
  • 158 Answers
Unplug all the Harddrives, Cd Drives attached to the motherborad. Try turning up the system. If it boots, you may to have to change the I/O cables.
Still if it is amber, then your motherboard is having the problem with. As long as the LED glows PCU gotta be okay.
Kindly get back for futher help
  • Prashant Bharadwaj
    Prashant Bharadwaj Jan 10, 2009
    Now carefully remove all the components from the motherboard. Run the computer only with Motherboard, processor and RAM. Turn it on. Check if there's any progress. We are trying to scale down the issue here.
How do I fix a dimension E510 with a solid amber power light?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 25, 2014 | Dell Dimension E510 PC Desktop
Dell dimension c521
it could be and issue with the system board to confirm that try to run a HDD test once using an alternate video source to check id display coes on alt monitor...are u able to enter the BIOS check once.
Feb 12, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
I've got a Dell Dimension 5150. After connecting to the mains the power light is blinking amber for some time, it then disappears and only then the computer can be booted. Unfortunately this delay is...
Check POST Boot messages for a flat Battery; Check Front control panel circuit over (remove); Check other USB connectors; Try a replacement Power Supply Unit.
Sep 12, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Tower power button flashes amber but will not start
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
May 13, 2010 | Dell Dimension™ E510 PC Desktop
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Steady amber Power light
You are looking at a new mother board. I would take it to a certified technician shop, so they can run a stress test on the motherboard for final benidiction.
Aug 13, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell E510 has a solid amber light, no light codes or sound codes. Unit powers up but will not boot. I unplugged and replugged all the wires to no avail. Does anyone have a clue as to why?
Contact dell technical support for a replacement motherboard. If I remember correctly this model had a recall due to faulty capicitors and should be replaced even if you are not under the service agreement still.
Jul 14, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Wont boot up
Check to see if the Hard drive cable is securley attached to the mother board, and is powered up. Also, try taking the Hard drive and seeing if it works in another computer. If it does not work, then it is a bad hard drive that is causing this problem. Else, it may be a bad mother board. I Had this problem before, with a Dell. Called Tech Support, set a guy out, 30 minutes later, Problem solved. Best of Luck Dude.
Jan 22, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension E510 PC Desktop Logo
409 people viewed this question
Alun Cox
