Question about Canon BJC 80 InkJet Printer
When powering up canon bjc80 what should it do?
I have a bjc80 and when I plug it in the ink carrier keeps going back and forth then it finally stops. I do not have any software to plug it into a computer and I don't have any cables that look like that (old style printer). I just wondered how many times should it go back and forth. No error lights come on at all. Just the power light is on. thank you!
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
My printer will not print, keeps displaying ( clear carrier jam! ). How can I fix it?? Do I need to buy a new printer or is this an easy fix. I 've unplugged the printer and checked ink cartridges...
Turn the printer off and unplug it from the wall. Press and hold the power button for sixty seconds. Open the top of the printer to make the ink cartridge carrier accessible. Grab the ink cartridge carrier with your hand and slowly move it back and forth until it moves freely. Then plug the printer back in and turn it on. That should solve your issue.
Sep 25, 2011 | Dell V305 All-In-One InkJet Printer
Own a Canon Pixma Printer MP160. Receiving message "Ink Absorber is almost full". How do I fix this problem? Thank you, Cathy
There are two ways to fix this:
First Solution - Clean the Absorber pads
The absorber pads is filled with waste ink. Access the printer to get these two absorber pads and clean it with soap and running water. After cleaning return it back. To access the printer, first open the top cover for the ink cartridge. The absorber pads are seated under the cartridge carrier, when the cover is open the cartridge carrier will move to the middle leaving the two absorber pads accessible. Use a tweezer to lift up the pads.
Second Solution - Reset the Printer to clear the error
1. Turn off the printer (but make sure power cable is plugged in wall outlet).
2. Press and hold down the Stop/Reset button
3. While holding the Stop/Reset button, press and hold down Power button.
4. While holding down the Power button, release the Stop/Reset button.
5. While still holding the Power button, press the Stop/Reset button twice.
6. Now release the Power button.. (wait until it display "service mode")
7. Press the Stop/Reset button four times
8. Turn off the printer
When you turn on again the printer it will surely works again.
Much appreciated if you could give a four thumbs up rating for this solution.
Thank you for using Fixya.
Mar 01, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Have a 5100 error on a canon pixma mx 860 printer
There are a few issues that cause a 5100 error code. 1) The encoding strip may need cleaning. 2) There is a paper jam. 3) The printer may need to be reset by turning it on and off. 4) The ink tanks may need to be properly snapped into their carrier. 5) The printer may need service.
The solutions to try
1) Cleaning the encoder strip. Use a cotton swab and isopropanol (rubbing alcohol) or window cleaner. A flashlight will help you see any grease on the encoding strip. With the printer on, open the printer by lifting the scanner unit until it locks. Unplug the power cord from the printer and wait until the LEDs are no longer lit. At this point you will be able to slide the cartridge carrier back and forth. To start, slide the carrier to the right. Look for the clear plastic strip (the encoding strip) in front of the carriage drive belt and look for any grease or other dirt on the strip. Remove the grease with a cotton wab moistened with the isopropanol. Look at the strip from several angles to check for any grease along the entire strip. Make sure you do not remove the grease from the chassis (metal rail). Move the cartridge carrier to the left and check the right side of the strip. When all of the grease is removed, lift the scanner unit support and close the unit. Plug in the power cord and turn the unit back on. Often grease gets on the encoder strip when you remove a paper jam. If you proceed to the next step, you may have to repeat this cleaning.
2) A paper jam
Carefully pull any sheet from the rear tray or paper output slot. Detach the rear cover and fully extend the rear tray support and try to pull the paper out slowly. Otherwise try turning the printer off and on - the sheet may be ejected. Remove the paper cassette and pull any paper out slowly that is in the front area. If needed, try removing the paper cassette and any paper in the rear tray. Then turn off the printer and unplug it. Set the unit upright on the left side and try to pull the paper out. Return the printer to the usual position when done. Replace the cassette, plug in the power cord and then turn on the printer. This will delete any documents in the printer queue. Check for foreign objects around the paper output slot. Remove any foreign objects with the unit off. Close the rear cover completely. Make sure that the paper isn't curled up.
3) Turn the unit off, unplug the power cord and wait 10 seconds or longer. Plug in the power cord and press the On button. Wait until the printer completes the cycling process before trying to print again.
4) Verify that the ink tanks are properly seated. With the printer on, lift the scanning unit up until it locks. Press on the black circle on each ink tank until it snaps firmly into place. Check if the ink lamps light up red. Make sure the protective shipping covers was removed from the ink tanks. If the unit has the remaining ink level detection feature disabled, replace the ink tanks. Close the scanning unit.
5) If none of the above solutions work, contact Canon if the unit is under warranty. Otherwise, decide if the service is worthwhile for an out-of-warranty printer.
I hope this helps.
If the paper tears when you try to remove it, open the scanning unit with the printer on and unplug the printer. Then look for and remove the paper. Use a flashlight to check for paper and other foreign objects in the corners. Slide the cartridge carrier back and forth to check the corners completely.
For pictures check the support site: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx860#ServiceAndSupport . Search for the error code 5100 and then follow the links.
Jan 09, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Wate ink pad full, need to know how to take it out and relpace it
You need to take apart the printer from the top of the print cartridge area. The waste ink pads are below the printhead (they are small rectangles of a rubbery material). (One is where the carriage stops during a cleaning cycle. Another keeps the ink from getting everywhere in the printer when you do an edge-to-edge picture) In some cases, you need to remove some screws to get the print cartidge carrier and print head out of your way.
Have lots of newspaper around to keep the ink from spreading. Pull out the pads and either replace them or blot most of the excess ink off. Then put them under running water until the water runs clean. Let them dry (use a blow dryer if you want to speed the process up). Also blot the excess ink from the plastic "trays" that the ink absorbers were sitting in. Then reinstall the pads and reassemble the printer.
Finally reset the printer's waste ink counter. To select something... Use the '-' and '+' buttons and then the "OK" button.
- To go back... Use the "Stop/Reset" button
- To reset... Use the "On/Off" button (only after you've gone back as far as possible it seems)
1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
2. Select "TEST MODE"
3. Select "[8] ETC.."
4. Select "[4] EEPROM CLEAR"
5. Select "[1] INK COUNT"
6. Press the [OK] button.
7. Press the [Stop/Reset] button (returns you to the TEST MOD sub-menu))
8. press the [ON/OFF] button (which resets the printer)
On other Canon all-in-ones you press and hold Resume while pressing the Power button to enter the Service mode.
Please note that the counter is calculated to be reached near the end-of-life of the printer. Additional failures may occur soon.
I hope this helps.
Sep 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP160 Printer "Ink Absorber is Full"
Sep 14, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark 5400 cartridge carrier slams up against back???? Won't stop!! It's a new printer, put in a high cap black and low cap color cartridge. Any ideas how to fix this?
Cartridges may not be seated properly. Remove all the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds. Plug printer back to power source. If printer ink cartridge carrier still slams on the sides, encoder strip of the printer might be damaged. If it's still within warranty from where you bought it, have it replaced at that store. If ink cartridge carrier is not slamming to the sides, re-insert the cartridges. Make sure there are no obstructions along the carrier's path. Close the cover. Let the printer print the alignment page. If it's still going to slam the carrier, have it replaced.
Apr 07, 2010 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
I am also having the 6A00 error code. When I open
OK here the codes
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
The green power light on my Canon BJC80 flashes and will not stop. I have not used it in MONTHS so clearly the ink cartridge is dry. Is there any link to the flashing light and the out of ink status?
try this
Indicates Waste Ink Full error
To repair follow the steps below
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Jun 26, 2009 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
60 people viewed this question
old marine
old marine
