Question about Wurlitzer Crosley WR18 Mini-Bubbler CD Player CD Player
CD opens and closes perpetually. CD won't play.
After a power outage, my WR18 started acting strangely once power was restored. Now when I close the CD tray, it closes, but then it immediately opens up again. The radio works fine, but the CD tray won't stay closed. Does this sound like damage from a power surge?
  • Anonymous Jul 20, 2008
    I have a Wurlitzer WR-18 jukebox, when I close the CD tray it opens right ba ck up!! Help would greatly be appreciated.
    Thank you,
    Mike
    Mike7720@aol.com
  • Anonymous Mar 12, 2014
    the cd tray won't open
  • 883 Answers
Likely yes. does not sound like coincidence. try this: search ebay for an AS-IS item for $1 and use it for part-swapping. first to swap-the main circuit board holding the micro chip.
Posted on Jun 04, 2007
GE Quiet Power 3 won't start when door is closed.
What is the exact model number? This may be an issue with the cables that connect the door to the power supply.
Apr 06, 2018 | GE Dishwashers
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
DVD Drive opens automatically when I start up the pc and won't recognize disc
I had the same problem and it was the sata cable, I would check this and change it for one you know is good. hope it solves your problem.
Jan 09, 2013 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Cd draw opens on power up and won't play a cd keeps opening after closing
This unit needs replaced it has seen better days sorry. The only thing you can try is shut off all power to the PC then unplug the PC and that cd drive from the rear of it. let the PC boot all the way up so you see your desk top. Shut it all the way down un plug PC hook back up the wires on the back of the CD player let it boot back up see if this stops it.Remember to rate my solution this is how i earn my achievements also testimonial Thanks much in advance.
Apr 22, 2012 | Dell Dimension 3000® Pentium® 4...
I have a 5CD changer stereo system. It is very close to the RS2652 and I use it every day in my classroom. Several weeks ago, it began behaving strangely. First I could only get one or two cds to play...
It very well could be a lightning related issue. From previous experience servicing equipment, I have found that electronic equipment that is hit by lightning acts strangely very comparable to what you are describing. Function switches are performing different functions usually due to shorts from the hit. It tends to act normally for bit, and then sporadically do something completely different from what it is supposed to.
As far as service, depending on the age and original cost, you probably are better off getting a new unit. It has also been my experience even if something electronic is repaired, it still may act strangely doing something else later if it was indeed hit. Unfortunately most electronic repair charges can be rather high, maybe 50.00 hr or so, plus parts and a bench fee just to look at it. I have replaced many items for customers after they had them repaired because of this. Check into your insurance. It you have a higher deductable, it may not be worth it. Insurance companies also tend to charge higher premiums as well. Never hurts to ask, but in the long run a drive to the store might be worth it.
Feb 19, 2011 | RCA Audio Players & Recorders
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
Denon CD player DCD 920. When using the open/close button once, the CD-door opens but when it is open, without any waiting time, it immediately closes again. If i operate manually the open/close switch on...
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Oct 14, 2009 | Denon Audio Players & Recorders
Microwave won't shut off
The door switches are what tells the microwave that the door is opened or closed. If they play up they could be causing your microwave to act strangely.
Mar 25, 2009 | GE Microwave Ovens
Wurlitzer Crosley WR18 Mini-Bubbler CD Player CD Player Logo
583 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
