Cell Phones Logo
A
Anonymous Posted on Nov 24, 2012
How to connect audiosonic bluetooth speaker car kit to mobile phone?
Shayne Wellington
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 24, 2014
Shayne Wellington
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1212
Points
This is for the little audiosonic hands free car kit that you get from kmart for 7 dollars : you need to hold the on button for 6 seconds then you should see the light flashing blue and red once this is done select it on your mobile and away you go
The manual tells people to pair it another way which is incorrect this will work as ive done it several times to many devices
Anonymous
Level 1:
New Friend:
  • Posted on Feb 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1212
Points
Hi, did you solve this problem. Having the same one with my iPhone
  • Shayne Wellington
    Shayne Wellington Feb 24, 2014
    just hold the on button for about 6 seconds this will put the phone into pairing mode... it should flash blue and red
3 Related Answers
Anonymous
  • Posted on Mar 24, 2009
SOURCE: can't connect my nokia 6300 to Parrot Bluetooth Car kit V5.1
Try "1234". That's the code on my parrot kit.
Anonymous
  • Posted on May 06, 2010
SOURCE: I have a Nokia CK-7W hands free kit in my car. I
sometimes my radio doesnt work with the ck-7w is this a common problem
Anonymous
  • 3 Answers
  • Posted on Sep 13, 2010
SOURCE: 3200 Ls Color Handsfree Bluetooth Car Kit: what is the bluetooth password to connect my black...
1234
Connect my phone to my bluetooth in the car
Put the car in discovery mode and then turn on Bluetooth on the phone and the car should show up and select it to pair.
2answers
How to pair ny mini bluetooth craig speaker to my
Turn on the bluetooth of your phone first: Go to settings>Wireless and Networks>Enable Bluetooth and disable discovery limit in bluetooth settings. After that make sure the bluetooth in your speaker is on and let your phone search the speaker and let it pair with it after that go into your phone's music player and look for its play options and if you see via bluetooth click it. Just let me know if you need further instructions or you could watch this video showing how he pairs his bluetooth speaker from his phone DBEST London Bluetooth Mini Speaker Review
Oct 16, 2014 • Cell Phones
How to connect to nexus dsp bluetooth sunvisor car kit to mobile
http://www.supertooth.net/img/one/mdp_EN.pdf
0000 works for the "nexus dsp bluetooth sun-visor car-kit" aswell
very helpful , thankyou. Colin Mc Donald & J. Van
Bluetooth on my phone is not working right in my car
your car likely has Bluetooth capability already built-in and can communicate instantly with your phone.Install the Bluetooth car kit. It is a sipmle device with a fairly simple installation. Every Bluetooth flex cable bluetooth car device comes with a step-by-step guide to help.
5helpful
2answers
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
1helpful
2answers
I need a user manual for thisSFK404 Bluetooth Visor Mount Handsfree Speaker but I cant seem to find one online so i could download it
didnt find any either too old but here is specs.
Model No: SFK404
Simply attach the Visor to the Sun Visor or any other suitable place, connect the Bluetooth hands free kit up with mobile and away you go.
Superb Quality simple Bluetooth Car Kit with Caller Id Display and Number Keypad for easier dialing.
Specifications
* Talking Time : 5 Hours * Standby Time : 150 Hours
* MIC : -47+/-1.5 * Power Consumption : Max 250mA
* Carrier Frequency : 2400MHz to 2483.5MHz * Transmission Power : Typ.1.0 dBm
* Operating Temperature : -20 ~ 70? * Storage Temperature : -40 ~ 85?
* Speaker : 8W, Max 1.5W * Digital Volume Control
* AC/DC Adaptor : 5.0V / 1A * Car Charger : Out : 5.0V/800mA
* Battery : 3.6V, 950mA Li-ion Rechargeable NK8200 series compatible
Main Functions
*Superior noise suppression *LCD Display - Caller ID/Calling time
*Excellent echo cancellation *Support Making/Ending a call
*Super full duplex *Support Voice Dialing, Number Dial
Compatibility : Compatible with all Bluetooth mobile phones
Profile : Supports for both Headset & Handsfree Profile
Bluetooth v1.1 compliant
CSR(BC02)
CDMA & GSM & TDMA
- Approvals : SIG, CE, FCC certified
FEATURES :
Last Number Called
Voice Dialing ( Providing the Phone Supports the feature.
Number Dialing
Speed Dialing
Selct wether to answer, Reject and End Calls
Volume Control
Power On and Power Off Feature to reserve battery power.
Rechargable Battery
Battery Power Status
Incoming Caller Alert ( Visor will Play a Meldoy and the Led Display will Flash Blue )
Connect to Pc for firmware upgrades ( Cable Supplied )
Bulit in Speaker
Built in Microphone
Bulit in 4Mb Memory
Noise Suppression
Echo Cancellation
Supports both Headset and Car Kit Profiles ( Phone Dependant )
Transferring Audio Feature ( Both from Headset and Handset )
Standby 150 Hours ( Uses a Nokia 8210 Battery so you can have a spare battery or simply purchase any nokia phone model in car charger to charge from your car. )
Talk Time 5 Hours
1 Year Warranty
Compatable with all Bluetooth Enabled Mobile Phones.
Handset supporting headset profile
Ericsson: R520m / R520m, T39 / T39m / T39mcc, T68m / T68mc
Sony Ericsson: P800, T68,
Motorola: A803, T280i, TimePort 260C V1.1
Philips: Fisio 825/826
Samsung: X7700
Sky: IM6200
Handset supporting handsfree profile
Motorola: V525, V600
Nokia: 6310 / 6310i, 8910 / 8910i, 3650, 6230, 6600, n-Gage
Sony Ericsson: T68i / T68ie, T610, T613, T630, Z600
Siemens: S55, S56, SX1
Panasonic: X70
Jan 22, 2009 • Cell Phones
18helpful
2answers
Blueant supertooth not pairing to samsung omnia i900
Hallo Stu,
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
4helpful
How can i reactivate my blueant blue tooth on my motorola ic902?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
8helpful
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
3answers
LG TU 550 (australian model)
you have to buy bluetooth headset
and then connect to your mobile
for more information
you can mail me
[email protected]
thanks
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
