Question about Bush 5693D 24" TV
TV SCREEN PICTURE SMALLER
Suddenly the wide screen picture narrowed ..tried the usual settings, upplugged over night .. Still the picture is very narrow in the middle of the screen .. Has something blown is it dying .. thank you..
  • sadie brown Jun 06, 2007
    Brilliant thank you soo much .. sorry I didn`t reply earlier just got message .. will watch the 9 inches with the lines till one of us dies .. xs
  • Anonymous Jul 01, 2008
    tuned dvd into av setting only plays back in small picture mode .
    reprogrammed several times
    President:
  • 3,130 Answers
Yes you have a problem I'm afraid in the pincussion or horizontal width circuit. These circuits usually have alot of high voltage in them and is not a safe place to be experiementing around with. Most of the time, with a problem like this, there are bad capacitors or a correction transistor has failed. If the set is over a few years buy a new one. Good Luck
Posted on Jun 04, 2007
Picture doesn't fit screen. A 1-1/2 inch wide band on top and bottom of screen. Have tried the picture button on remote but it only gives me options ie: Panoramic, standard, wide etc. Nothing seems to
Many units will self adjust the image size, but the size of the image you will see depends on what size it was originally recorded in. You can change it in the settings of the TV but most likely it will not go bigger if it was shot smaller.
Feb 05, 2015 | TruTech PVS31170S1W 17 in. LCD Television
TV picture is smaller than screen, how do I make it bigger?
See if there is a "wide" button on the remote. Should scroll through the display size options
Go to menu and picture adjustments are there as well
Mar 20, 2014 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Picture does not fill the whole screen
Check its picture aspect ratio settings.
Apr 28, 2012 | Haier Televison & Video
Last night when I turned my tv off it was working fine. I turn it on today and the picture is bigger then the screen itself, and my Video 2 isn't working anymore, it doesn't even acknowledge that I...
On your tv remote click on the "wide" button and change the setting. Also you could try the setting on your cable box that pertains to the size of your screen. If all that fails, go to the website of your tv maker and see if they could send you a manual or give you advice on how to make screen smaller.
Jun 09, 2011 | Televison & Video
Picture on screen is narrow and I cannot select normal view
use menue button on tv if this does not work change main board in tv
Jun 05, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mintek piece of ****
Have you try the TV Menu in the remote control and then switch the window settings. I had the same problem and it turned out to be the window setting was in the smaller screen
Nov 09, 2008 | Mintek DTV-233 23 in. TV/DVD Combo
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Aug 07, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Bush 5693D 24" TV Logo
308 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
