Question about Refrigerators
Water drains from freezer compartment into refridgerator
Whirlpool refridgerator model ET18NK / ET18MN. Water drains from freezer compartment into center of refridgerator then freezes. I've placed a bowl in refridgerator to catch water. 01/09/09
    Sniper:
  • 51 Answers
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 09, 2009
  • jimbo460 Jan 09, 2009
    i hope this helps
I hv Toshiba GR-M-37kchs 10 years old model fridge. Cooling system of the freezer compartment stopped working everyweek. I hv also not foudn drainage plug of this model. anyone can help me please
Posted on Apr 29, 2013
Leak from freezer into top of refridgerator
There is a drain in the freezer compartment to allow excess water to drain out. It is plugged. Go on Utube and search. There is a video on how to unplug it. It might not be your model, but will be close
Dec 22, 2014 | Whirlpool Refrigerators
I have a Whirlpool refrigerator. Model # ET1CHMXKBO3 and it leaks water into the bottom of the refrigerator. Water also freezes on the bottom of the freezer compartment. I checked for a clogged hole o
When your refrigerator defrost the water runs into a drain pan in the bottom/underneath the refrigerator, You will need to first unplug and remove contents from freezer and proceed to remove the air tower in the center of the back panel, underneath the evap. coil in the center is a hole that leads to the drain and it is iced over and the water is not able to flow.What i do is get a hair dryer (be careful not to melt the plastic) and defrost/melt the ice. You will need a towel to start and once you think you have the ice removed get some hot water and pour in the trough to make sure it flow's to the drain pan. When the flow is good put the part's back and make sure the refrigerator is level from side to side and slightly tilted towards the back (front to rear)!
Dec 24, 2013 | Whirlpool Refrigerators
Have whirlpool ET18NK/ET18NM refrigerator-food freeze in the center of frig and veggie bins--water collects in bottom of frig to overflowing if I don't keep a container in middle of top shelf to catch ...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 27, 2011 | Refrigerators
Model ET18NKXDW06. Water dripping from freezer down back of refrigarator. Placed bowl underneath opening to catch water. Should be going down to catch pan right???? Help Nell
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Gene
Aug 10, 2011 | Whirlpool Refrigerators
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
Good luck,
Gene
I have a whirlpool refridgerator model ET18NK 18 cubic feet (freezer on top). Water appears to be draining from freezer down to fridge, and landing under crispers. Is the advice for fixing this fridge,...
Unfortunately, we do not have any troubleshooting suggestions for your concern. We recommend service for a proper diagnosis. If you would like us to schedule service, please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with the website you reached out to us on (fixya), brief description of your concern, your name, address, a phone number and best time to reach you along with your model and serial number.
Jan 17, 2018 | Whirlpool Refrigerators
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Water in freezer
Most refrigerators today are ice maker ready. If the plugs that were installed in the cabinet and freezer compartment that are used to plug the "ice-maker ready" holes are removed, then moisture seeks it's way into the freezer and freezes.
You will need to replace the plugs to prevent this from happening. Do not use tape to cover the holes as most tapes are not watertite. You should be bale to find replacement plugs at your nearest home center, or from the manufacturer of the refrigerator.
Jan 15, 2009 | Whirlpool Refrigerators
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
768 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
