Question about Averatec 3200 Notebook
On the power supple light flashes rapidly and comp. wont turn on
Power on
  • kulgrpa Jan 09, 2009
    once i plug in the powert supply into the laptop the solid green light on the supply starts flashing and the laptop will not turn on. the battery is also dead so it will not charge
    Guru:
  • 829 Answers
Hi , Whts the exat problem for me to understand and then help you , Plz be more specific.
Posted on Jan 09, 2009
Grand prix front turn signals lights will not work but rears flash rapidly.
Definitely not the flasher, as long as it is flashing or blinking somewhere. Rapid flashing indicates a burned bulb, but since you already tried new bulbs in front, possibly bad bulb sockets, loose connectors, or a bad ground for the front bulbs. If you have a test light or voltmeter (multimeter), check for power at the socket when turns are on. If power then at the front, try new bulbs or trace the ground for those lights. If no power to the socket for turn signals, recheck wiring.
Apr 02, 2013 | 1995 Pontiac Grand Prix
1998 mustang the anti theft lite is blinking car wont fire it turns over
might wana have that theft turned off i had mine turned off on my 99 due to too manny problems i was like wtf so i had it turned off so now u dont need a key with a (chip) if u turn it off saves alot of time! down the road its stupid
Mar 01, 2013 | 1998 Ford Mustang
2001 blazer wont start . gas gauge quit working ,fuel pump wont work will work suppling power to port in fuse panel. ecm fuse ok,relay ok
Sounds like the ignition switch has gone bad and will need to be replaced. Turn the ignition switch to the on position again and check to see if there is power to other items like the transmission and accessories. If there are a few items that are not working, good chance that the ignition switch has gone bad and is there any security light on the dash flashing???
Thank you for using fixya and keep us posted.
Nov 17, 2010 | 2001 Chevrolet Blazer
Green light is flashing in back of computer but it will not turn on
if the green light you're mentioning came from the power supply, you need to replace it. green light flashes from the LED at the back of the power supple serves as an indicator if you have a good or a faulty power supply.
Aug 07, 2010 | Compaq Presario 5000 PC Desktop
I had a power outage and when the power returned my computer was off as expected. I tried to push the on/off button but only get the power light in the button to flash and I hear a sound in the speakers at...
sounds like your power supple has failed - you can pick any ATX powersupple from bestbuy or a retail store get a 400 watt or better ...
this is a easy way to see if the computer is shot - if a new power supple wont work - then you might need a new computer and you can return the power supply .... 40 to 50 bucks for a good power supple vs paying some 50 bucks to tell you the power is shot plus the part = 100 fix and it's easy to put in ... if you can plug up a hair dryer or a coffee pot you can change a power supply
see this link
http://www.metacafe.com/watch/803436/how_to_install_or_change_my_computers_power_supply/
Dec 28, 2009 | Gateway 507GR PC Desktop
On my desk-top presario
HP/Compaq has had alot of power supply issues with this series of computers. Do you have another power supply you can try in this system? If the light is flashing rapidly, it is usually a power supply. Fairly cheap and easy to replace.
Jan 26, 2009 | Compaq Presario SR1050NX (DW257A) PC...
Hl1440 drum indicator flashing
ok turn it off take the toner out clean all the terminals put them back in make sure everything is closed properly turn the machinie back on and let me no what happenes then
Sep 12, 2008 | Brother DR-400 Replacement Drum - 20000...
Strange behavior
Initially, pls try disabling the hibernation feature of your computer.
Other than that, would appreciate if you can post back the make and model of your computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Computers & Internet
Averatec 3200 Notebook Logo
32 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
