Question about Toshiba Satellite A105-S4004 Notebook
Toshiba A-105 Satellite, LCD Screen problem
Hello, I've had the A-105 for about a year. Recently the LCD screen has started to flicker--when it's at its worst, it goes completely white. I've taken it apart to check the wiring and see if if a connection was loose or if a wire had gone bad but that doesn't seem to be the case. When the screen starts to act up, if I press my thumbs against the plastic near the bottom of the screen or just adjust the angle of the screen, it goes back to normal but the solution is only temporary. Any ideas? Thanks!
  • Mike Matha Jun 13, 2007
    I cracked the case open again, but all the wires look fine. The problem is getting increasingly worse. I hadn't thought about temperature--I rarely turn the machine off--but that is an idea.
    I will say, though, most of the wiring is trapped underneath plastic that I can't figure out how to remove.
  • Mike Matha Jun 14, 2007
    Hello again,
    I popped the case to check to see if I could get underneath the plastic like you said. But upon further examination, I saw that most of the wiring is not near the motherboard. There is about one inch of wiring that feeds from outside the LCD screen and reaches a port (don't know the technical term) to plug in on the motherboard. It looks like most of the wiring is inside the plastic casing of the screen. However, I have no idea how to open the casing. I can crack open the bottom slightly, but it doesn't seem to want to open beyond that.
    Thanks again.
Are you crazy, A HAIRDRYER! there are screws under the rubber sticky pads. When your LCD fails for apparently no reason there is a voltage converter similar to the balast on a flourescent light usually under the LCD screen not behind it. The next time your LCD goes out shine a flashlight at it. If you see a faint image there is no power to the backlight of the LCD. Also check your lid switch, and in windows under the power settings you can tell it to do nothing when the lid is closed as a work around to a bad switch.
Posted on Jul 08, 2007
  • 883 Answers
When you "adjust the angle of the screen", that can only be a faulty electrical connection. Try again at the mainboard connector.
Posted on Jun 04, 2007
  • Marty marty Jun 13, 2007
    Many of these screens use a interlocking plastic shell that requires no screws. You can try softening the plastic slightly with a blow dryer, but be careful not too much heat. Also, look for special round plastic "buttons" that hide the screw under them, then remove the buttons with a jeweler's screwdriver.
Screen flickering
I've had a couple of problems with mine, what it usually is is the wires coming loose, I've also had to replace the screen.
May 20, 2012 | Toshiba Satellite L505-S5966 Notebook
Flickering screen Toshiba P105
Flickering, always cause by LCD cable. Change it at any computer shop or service center and its not so expensive
May 08, 2010 | Toshiba Satellite P105-S6104 Notebook
Screen Flickers
Sounds like your screen is failing. Could be just a loose connector behind the screen (pressure changes the screen display), but best advice is to replace the screen.
Oct 04, 2009 | Toshiba Satellite M305D-S4829 Notebook
Screen flickers and dies
You have a faulty LCD inverter board.. Go here for instructions on how to replace and find a new one, or you can search on ebay for one. http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Sep 11, 2009 | Toshiba Satellite A105 Notebook
Laptop screen constantly flickers and whites out
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
Aug 15, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Flickering Screen on Model P105 Toshiba Satellite
on the back of the LCD is a cable that goes from there to the Motherboard. Try reseating that cable on both ends. If that doesn't fix it then it has to be a problem with either the screen or the cable behind the screen.
Aug 11, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Display
If you've replaced the LCD Panel already, then chances are good, the failing part may be the FLR inverter. It's a thin little chip about 3 or 4 inches in length that bridges the connection between the LCD and the motherboard. It's location varies from computer to computer though, so you may have to check with manufacturer documentation. They're not too terribly expensive to replace though, much cheaper than the LCD panel, anyways.
May 09, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite laptop won't start
From Toshiba Manual:
"Over a period of time, and depending on the usage of the
computer, the brightness of the LCD Screen will
deteriorate. This is an intrinsic characteristic of LCD
technology.
Screen will dim when the computer is operated on
battery power and you may not be able to increase the
brightness of the screen.
Try pushing Screen contrast to Max when on AC charger connected.
Allow several hours charging battery with PC off.
If battery does not completle charge Or if older than 3 years CHANGE it.
Jan 04, 2009 | Toshiba Satellite A65-S126 Notebook
Vertical lines in my laptop screen
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
LCD monitor problem
What you described sounds like a loose LCD cable inside. Does it flicker or have video distortion when it's moved?
Jun 27, 2007 | Toshiba Satellite A105-S2716 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
215 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
