Question about Maytag MEY12F7E Air Conditioner
The fan will work occasionally in my ac window unit.
When turning on my Maytag(MEY12F7E) it either works, or emits a low hum. When it emits the low hum, the fan is not turning (I know that the fan is not turning, because I opened it up, and could see this). It does not stop working in the middle of use, if working on an initial start. I'm assuming it's a fan motor/blower moter of some kind, etc. Just not sure, and it could be a pretty tough deal for me to get this thing out of the wall to take apart(it's possible, but I want to know costs before I get into to something like that) Any ideas??? Thank you for your time, Bryan.
  • Maytag Master
  • 5,568 Answers
If you can access the motor shaft, try this: (Pull AC plug!)
Using a spray penetrating lubricant such as WD-40 and a towel to catch the drips, spray it at the point where the shaft enters the bearing while turning the fan with a finger. Penetrating lubricant does not lubricate for the ages, it is supposed to break down films and rust.
Try to sense if it starts turning easier. If it doesn't, the gummy bearing may be on the other end and you may not be able to get to that one.
Cheap motors commonly have sintered phosphor-bronze bearings with embedded graphite and the graphite will gradually build up and finally impede the fan motor that doesn't have the torque to overcome the gummy bearing.
If you do replace the motor, and have a Johnstone Supply in your area (chekc white pages, they don't advertise much), it will probably be <$20 even if an OEM part. Johnstone is 'wholesale' the the repair trade but I have never had any problem buying from them. I generally pay ~ 50% (sometimes only 1/3) of what a dealer will charge.
Posted on Jan 09, 2009
    Sergeant:
  • 311 Answers
Bryan the manufacturers are making motors cheaper and cheaper.one way of doing this is a capacitor.it stores energy and can give the motor a kick start.you can look at your wiring diagram to see if blower fan curcit has one.,but the diagram is also in the cabinet.i know it not the easiest thing too think about getting into,but its like most things once your done you think that wasen't so bad.if its the blower though it can be a bear.they are definitely not my favorite job.also small chance there can be somthing in there stoping the fan from getting going but you would have spoken of a noise.anyway their's a start for you God bless ,tom ps you could get a price on the cap and fan motor.also non genuine [after market] are much cheaper.when owned my appliance business the parts supplier could tell me if there was a non-oem part
Frigidaire window air conditioner, new, fan won't run
slide out and spin blade by hand. should be able to tell if anything restricting rotation
May 05, 2013 | Dometic Rooftop RV Air Conditioner
When I turn on the AC I only get a hum, no fans or compressor
Check the capacitor to see if good. need help get to me ken
May 08, 2010 | Frigidaire FAS156N1A Air Conditioner
Will my air conditioner still work properly...
It will viberate pretty bad anditcould cause more trouble viberation of the tubing could lead to brittle tubes and premature breaking. replace the FBlade first.
Jul 03, 2009 | Maytag MEY12F7E Air Conditioner
I need to replace a blower wheel (and maybe motor) on a central air/heat system. anyone got a simple schematic?
I have a modle # M6Y12F2B-E Maytag A/C and the fan has stopped spinning. I sprayed WD-40 and it worked for a few minutes. My problem is how to remove the outer housing in order to attemot to service the fan.
Thank's B. Cruz
Jul 01, 2009 | Maytag MEY12F7E Air Conditioner
Need a new control panel for Maytag mey12f7e
Call this number, they can get you a remote, probably the easiest and cheapest route
800.935.0062
Jun 11, 2009 | Maytag MEY12F7E Air Conditioner
Kenmore Window unit 15,100 btu, Model 25372156200
with the hum noise sounds like you have a bad fan motor
May 26, 2008 | Maytag M7Y15F2A Air Conditioner
Fan Stops blowing air
Isthis a window unit? It sounds like it. There could be a problem with your fan switch or the fan motor itself? Multi-speed motors can lose one speed at a time. It really sounds like the fan motor is bad. If the compressor starts in the cool mode, and the fan doesn't, the fan motor could be locked up. See, if you can spin the motor by hand? If you can, then something is bad within the motor. Now, if the motor has a capacitor, check for a loose or burned wire. Good luck.
May 18, 2008 | Maytag Heating & Cooling
Maytag window ac unit
Feel the motor and see if hes hot ...... spin the fan by hand and see if it spins freely  if not the bearings have seized up.   So either rebuild the fan motor simply by replacing the bearings and oiling them and that should fix your problem.    IF the fan spins freely   OHM out the fan  and make sure there is no shorts or openings in the fan.     if your fan motor checks out good both mechanically and electrically  then your next step is to check the capacitor and control board
Oct 07, 2007 | Maytag M6D24E7A Air Conditioner
Emerson quiet cool
a real hummer. humm can be the sound of a short.but it sounds since u did only turn the fan on it hummed ...fanns are blower motors in acs the motor I bet ate it and needs a new one no way of fixing the motor but most are easy and cheap to replace...go or call an ac applance man ...see if he got a good used one for you or go the manufacture take model make serial no. sometimes u can spin the fan while on and it takes off again...this is dangerous so use a plastic long something but will dy again after u turn it off. good luck. CrazyLarry
Jun 30, 2007 | Emerson Quiet Kool 10MW42K Air Conditioner
Maytag MEY12F7E Air Conditioner Logo
291 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
