Question about Toshiba 65H93 65" Rear Projection Television
No power after reassembly
I disassembled the TV to move it. After I reassembled it, I have no power. Any idea where to look? Do you have a schematic?
  • karen_keller Jan 12, 2009
    This is a Toshiba 65Hx93. It's an Cinema series HD integrated Projection TV. Since it is not a DLP does your recommendation stand? thank
    karen
  • Anonymous Jan 12, 2009
    That safety switch would be the same as a reset? Once it is pushed a click is heard but the unit still does not come on.
    Champion:
  • 240 Answers
On the back of all dlp sets ther is a small safty swich that needs to be set reasemble back panel and also check lamp placment to make shure all contact swiching is set.
Posted on Jan 09, 2009
  • Daniel Conklin
    Daniel Conklin Jan 12, 2009
    ther is a contact swich in the light box and the rear chissis
Instructions to get access to the drain pump for currys essentials cdw60w10
The best bet is to go on line to the manufactures web site and ask customer services to let you download the schematic and manual, free of charge. You need this schematic to follow the procedures when disassembling and reassembling the parts.
Mar 16, 2014 | Dishwashers
Shower not draining iflo waste
The domed drain plug has to be removed periodically, disassembled, cleaned, and reassembled. Be sure to disassemble it in order so you can reassemble it correctly.
While the drain plug is removed, apply drain cleaner in accordance with the directions
Nov 10, 2013 | iflo Home
I need a detailed schematic of a 1990 ford f250 steering wheel column that includes directions for disassembly and reassembly
Go back to the dealer ,chat the storeman up nicely and he will print you off the parts picture so you some idea where it goes ,this vehicle is so oil that nothing is complicated about this motor as i repaired a 350 1989 model last week and apart from getting the plugs out after they had been in for 15 yrs their was nothing i found difficult ,just big and heavy with its twin rear wheels and a complete brake rebuild as well .Still think a ford transit diesel is a better motor though because at our fuel prices here in europe ? need i say more
Mar 30, 2012 | 1990 Ford F250
Lense taken apart, not sure how to reassemble
Sorry cannot help you. If it has more than 3 elements no one except an optical technician can reassemble the elements. Call Meade customer service. They may take it back knowing what happened????
http://www.meade.com/support/index.html
May 22, 2010 | Meade 124 Barlow Lens 124 Barlow Lens...
Hitachi Cordless Impact Driver gearing problem
The speed shift slider switch wasn't lined up correctly when the unit was reassembled.
Unfortunately, you going to need to repeat the disassemble/reassemble process once more.
I've been there. It doesn't take much to be out of alignment. Set everything to the lowest setting (clutch, speed) and take your time.
Best regards
Mike
Apr 22, 2010 | Hitachi DV18DCL 18V 1.5Ah Lithium-Ion...
Hello My Camera was dropped with the lens out,LCD screen message say's lens error, restart camera. this does not fix the problem. any idea's please
Slightly tap on the lens barrel while you power it on. I'm afraid that is all you can try at home. I suggest you take it for repairs, maybe they can fix it by just blowing compressed air in it and reassembling it?
Don't try to repair it at home. There are timed mechanical gears inside and can be impossible to reassemble without a schematic.
Nov 29, 2009 | Canon PowerShot SX100 IS Digital Camera
Reassembly of trimmer blades to motor body
Put the ware plate on the support bar.
On top of that install one blade facing up.
Then install the other blade facing down.
Put the bolts up through the support bar
Install the little rubbing blocks on bolts in slots in blades.
Place top stiff plate on top and install nuts.
Replace grease in gear box with stihl hedge trimmer grease onyy
Mar 19, 2009 | Garden
Need schematic for rear turn signal assembly
no need for it., one cable green is ground and the other is power.(orange or light blue)
Feb 23, 2009 | 1992 Honda VT 1100 C Shadow
Need instructions to reassemble Eureka vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12503&thid=680704
Posted by TamiLynn on Jun 18, 2008
I had to completely disassemble my Eureka Whirlwind Lite Model 410 bagless vacuum due to an excessive amount of debris that collected in an inconspicuous spot and now that I've reassembled it sounds like something from the motor is rubbing inside somewhere as if I put it together incorrectly. Do you have any schematics on what the insides should look like so I can put it together properly?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the schematics is to contact the Eureka Factory @ the listing I will give you below. Sometimes the owners manual have the schematics in the owners manual but if not they might be down loaded from the factory website or to contact them by phone
And ask for cust serv or the serv tech support or parts for the schematics. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 18, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Toshiba 65H93 65" Rear Projection Television Logo
319 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
