Question about Samsung HCM5525W 55" Rear Projection Television
Samsung hcm 5525w
I just bought this set and am having the same problems as alot of others. double vision and alot of extra red.however i would like to fix the problems my self. i have been in the electrical field for abovt 7 yrs. and feel very comfortable working on the set. if u have any advice or information that would be helpful i would be very appreciative!! my e-mail is jonb_1234 at yahoo
  • 4,234 Answers
If this set is new, a problem like this would be covered by warranty. If it is no longer under warranty, locate the convergence ICs which will be large black ICs attacked to a heatsink. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace the ICs. These should be marked STKxxx.
Keep me posted,
Dan
Posted on Jan 13, 2009
  • Mark Turner
    Mark Turner Oct 25, 2011
    I took my convergence board out and took it to the local TV repair shop, he had the IC Chips in stock. He desoldered and installed the new IC chips for $69 (chips & Labor)...cheaper than I could have bought the board for online.
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
My IQC50H94W Zenith projection TV has double vision...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 02, 2009 | Zenith IQC60H95W 60" Rear Projection...
Red and Green double vision
Depending on the age of the unit. You have a convergence problem. This is not uncommon. You can contact a servicer thru this homepage and have them look at it. Convergence issues could be anywhere from 200-350 depending on your area.
Dec 17, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Model 43FDX01B double vision with red ark across bottom . and no user manual.
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Oct 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Samsung HCP4752W double vision
*Screen Looks 3-D
*Colors wont align
Oct 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung 55" model hcm5525w
its the convergence problem in your power supply board
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Oct 05, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung hcm5525w rear projection tv
Extensive analysis revealed this unit to be for 120V 60Hz regions. If you use it in a region where the mains supply is 220/240V 50Hz then it won't work. In addition, the PSU will overheat, with possible damage to other modules.
One possible solution is a 120V 60Hz inverter, else Samsung may be able to provide the correct PSU for 220/240V.
Jul 14, 2008 | Samsung HCM5525W 55" Rear Projection...
Double vision on my samsung HDTV 1080i
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Feb 22, 2008 | Televison & Video
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Samsung HCM5525W 55" Rear Projection Television Logo
125 people viewed this question
Jerry Greenberg
Jerry Greenberg
