Question about Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony FD Trinitron Wega Model KV-24FS 100 TV. Good morning from Arizona. The set is connected to Direct TV, and I use that remote, except when watching DVDs. A few days ago, the screen went blank, and the standby/timer light repeatedly blinks twice. I hope for a solution, please help. Thank you.
  • donsaac Jan 09, 2009
    Thank you for your insights and advice. I'm gonna get a new TV!
    Novelist:
    Scholar:
  • 67 Answers
The 2X blink indicates that either the Horizontal output transistor is shorted, or the RGB amp is shorted (on the CV board).
The Horizontal output is probably the cause, and as a general rule, the flyback should be replaced along with the H-Out transistor. Good news is that Sony is pretty good about having parts in stock. In fact, a lot of times they will have the A board with all the parts on it for only a few bucks more than just the flyback, so you basically get a new TV (electronics-wise).
Any decent repair shop should help get the parts/do the repair for you if you don't have the electronic experience.
Hope this helps you...
Posted on Jan 09, 2009
WHAT IS THE MODEL NUMBER OF THE REMOTE FOR SONY TRINITRON 29 WEGA KV-SW29M50
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
No pix. Red LED blinks 2 times. ( sony KV-24FS-100 TVset. )
this is your over current protection B+, there is a short in the power supply of many of the circuits,fuse,diode,etc, check these carefuly with ohm meter....if fuse is open,only replace it with the same rating,make sure tv is not pluged into outlet...if you need to replace parts,use a desoldering iron,to **** off the solder at pin hole of the part being removed from under side of board also look for burnt spots,then you need wire wick to remove and clean in and the pin hole. reinstall is reverce order,,maker sure you make a good connection,and not over solder it ...keep it clean.hope this helps...........
Feb 22, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-27FS100 does not respond to remote
Good day.
Maybe there are loose connections along the IC that supports the operation of your remote. This could also hamper initial set up operation of your unit. Also, check on loose connections along the power supply.
Chris
Mar 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
27" Sony Trinitron Wega
Hi
Your TV's memmory IC or Main proccessor ic software get problem. You want to re-programm the ic to over come this problem.
Dec 25, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega KV MOdel
hello, you may have a manual switch botton problem, check those volume control switch, do some test, check the board for some cold solder or short connection. ty
Nov 19, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Tv doesn't respond to commands
Check the battery if its still good. if not replace with new one. if its still good, open the remote and inspect for loose connection. resolder if necessary. check also for possible crack pcb. good luck!
Feb 22, 2007 | Sony FD Trinitron WEGA KV-34XBR910 34" TV
Sony FD Trinitron WEGA KV-24FS100 24" TV Logo
175 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
