Question about Epson Stylus Photo R220 InkJet Printer
Printing R280 epson printing in brown, instead of black put in new black ink 77/78
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
What is wrong with my Epson R280 printer when the ink appears smeared down columns of a spreadheet
Probably dirty heads on the nozzle. In most inkjets there is a maintenance option to clean the heads. I would first clean the heads, and then make sure that the print heads were aligned. If that is all squared away then check for any driver or firmware updates. Finally get some rubbing alcohol and gently clean the print head. Sometimes if the printer is not used that often the ink will congeal and smear.
Oct 19, 2014 | Epson Stylus Photo R280 Series
My Epson stylus Photo R280 prints like its printing double and is very unclear..how do I correct this problem
You need to align/clean your ink cartridge. Look under the Printers, select your printer and go to Properties. There should be a tab for maintenance.
Feb 16, 2013 | Epson Stylus Photo R280 Series
Changed all my ink cartridges on astylus PHOTO R280 and now the print comes out with a green ting.
I suggest that you clean the inkhead with a wet paper cloth (just a little amount of warm water . enough to make the paper cloth wet).
Remember to remove the inkhead before wiping it with the paper cloth. After that, let it dry and put it back in. Try printing.
Dec 06, 2012 | Epson Stylus Photo R280 Series
I am printing pictures with my new Epson PX730WD and use only original Epson inks and Epson Premium Glossy photo paper; I had to put in a new original Epson black ink cartridge. Initially after printing...
Could be defective printer or maybe that is just the way it works and is unsatisfactory. If not happy with results try another printer after returning the Epsom. Check consumer reports for printers that do great job on photos and go that route.
Aug 28, 2017 | Office Equipment & Supplies
New Black ink in it and it still won't print in black
Printer not used for long time before? Ink dried inside head. Use spuit tube, connect to black nozzle. fill tube with cleaner. wait for 1 -2 hours.
Jun 27, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Problem with One Color (Yellow) not printing on Epson R280
Hello sir; Why don't try to press "resume" key before you print.
Apr 17, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus Photo R220 InkJet Printer Logo
147 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
