Question about AT&T 650530003417 Cordless Phone
Certain numbers on the hand held set do not respond when pressed. The nubers are 9 and, sometimes, 3 on the touch pad of the hand held. Why is this and how can I fix it? Thank you so much for any help you can provide.
  • snyder_peg Jan 10, 2009
    Will give a try at the solution suggested. In the meantime, I have to say how much I appreciate the help. Thank you so much!
    P.
  • 716 Answers
Sounds Like The Key Pad Backings Are Dirty This Happens With Time. You Can Fix It By Taking The Phone Apart And Accessing The Rubber Pad Behind The Numbers. Clean The Black Circles On The Rubber Pad With Rubbing Alcohol And A Q-tip Also Clean The Receiving End Of The Black Rubber Side Also Known As The Circuit Board. There Are Half Inch Or So Circles On The Circuit Board, Clean Them Off Using A Q-tip And Rubbing Alcohol As Well.
Please Note: Remove The Battery Before Attempting This And Find Any Screws That Are Holding The Device Together. After That Get A Small Flat Head Screwdriver And Work It Between The Gap Along The Entire Edge Of The Phone ( Starting With The Mouth Piece Is The Easiest) Please Take Extra Care Not To Break The Phone If You Still Cant Seem To Get It Apart Please Check Again For More Screws.
Posted on Jan 09, 2009
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
The start function on the touch pad is not responding, has all along been a bit funny but now wont start the machine cycle, its about 3 years opld
Try and unplug the unit, wait for a minute or so, plug back in and retest. Sometimes the computer get confused. Also clean off the touch panel, make sure your hands are dry before your retest. If this fails to work for you, get me the model number to I can research this further for you. Thanks and good luck.
Apr 20, 2016 | Asko Dishwashers
TOUCH SCREEN
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Initial Mode: Total Clear
Touch Panel Adjustment
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
• To adjust the position of the Touch Panel display
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
Reset temp
To Change Temperature Control Setting with Touch Pads:
• Freezer setting is on the left side of the display.
• Fresh Food setting is on the right side of the display.
- Press the warmer or colder pad for compartment and direction desired.
- Present control setting number will illuminate.
- Each time the pad is touched, compartment setting changes one number.
A display of 1 is warmest and 9 is the coldest setting.
NOTE: Setting the controls to the 0 (off) position does not remove power to the light circuit.
Control settings will vary based on personal preferences, usage and
operating conditions and may require more than one adjustment.
Dec 08, 2013 | GE GSS20IEP Side by Side Refrigerator
The numbers "3", "6", and "9" do not respond to touch when I'm attempting to set the temperature. the other numbers are fine. Additionally, the touch sensor for the oven light does not respond.
Your touch panel has some bad sectors and the only resolution is to replace the component. Disassembly and repair is not an option for these anymore.
Eric
Aug 19, 2010 | Jenn-Air Ovens
I use a hand held mouse. How do I disable the finger mouse
If by 'finger mouse' you mean the touch pad then yes you can enable or disable it as you wish.
For Acer Aspire models you need to press and hold the 'Fn' button and then press the 'F7' button (It has blue square on it with a hand over it).
Repeat the process to enable the touch pad.
Jun 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
HOW TO OPEN THE DOOR USING THE NUMBER PAD ON THE DOOR
this from the owners manual
Programming your own personal entry code
To program your own code:
1. Enter factory set code (keypad will illuminate when pressed).
2. Press 1/2 control within five
seconds of step 1.
3. Enter your personal 5 digit code.
Enter each digit within five seconds
of previous one.
Do not set a code that includes five
of the same number or presents
them in sequential order. Thieves
can easily figure out these types of codes.
Your personal code does not replace the permanent code that the
dealership gave you. You can use either code to unlock your vehicle. If a
second personal code is entered, the module will erase it in favor of the
new code.
If you wish to erase your personal code, use the following instructions:
1. Enter factory set code.
1 2 3 4 5 6 7 8 9 0
Controls and features
90
seconds of step one.
3. Press 7/8 control and 9/0 control
at the same time within five seconds
of step 2.
The system will now only respond
to the factory set code.
Unlocking the doors with the keyless entry system
To unlock the driver door, enter either the factory set code or the
personal code (each digit must be pressed within five seconds of the
prior digit). The interior lamps will also illuminate.
To unlock all doors, enter the factory set code or personal code (driver
door unlocks) and press the 3/4 control within five seconds.
Locking the doors with the keyless entry system
It is not necessary to enter the factory or personal code prior to locking
all doors. To lock the doors:
² Press the 7/8 control and the 9/0 control at the same time.
Activating/deactivating
May 19, 2009 | 2000 Ford Expedition
I need to set up one touch dial fax numbers
This should be what you're looking for:
Storing Speed-Dial numbers
1 Press Menu/Set, 2, 3, 2.
2 Using the dial pad, enter a three-digit
Speed-Dial location number.
Press Menu/Set.
3 Enter the number (up to 20 digits).
Press Menu/Set.
4 Enter the name up to 15 characters (or
leave it blank).
Press Menu/Set.
5 Press Stop/Exit
Apr 23, 2009 | Brother IntelliFAX 2800 Laser Fax
AT&T 650530003417 Cordless Phone Logo
260 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
