Question about Canon PowerShot A630 Digital Camera
Lens error Canon Power Shot A360
At frist the lens went in but it wouldn't close. The camera tells me it is a lens error and to turn off and restart camera, (which I did) now it is stuck halfway out. Any ideas?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
When Turning on the Canon Power Shot A530 the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Lens error restart camera
You need to turn it off than on.
May 16, 2009 | Canon PowerShot A95 Digital Camera
Lens wont extend, lens error restart camera
My wife's Canon SD200 got stuck with an open lens and the E18 error. I opened the case and wiggled things and still nothing. Then, I turned the camera on and started tapping the edge of the lens casing with the magnifying glass I'd been using (need the battery and memory chip in place and make sure you've transferred pictures to your computer before trying this). Voila! The lens closed. But, of course, it wouldn't open and still gave the E18 error. Well, one good tap deserved another and Voila! again. It opened. After a few more iterations - and cleaning the lens casing each time, it was back to normal. The trick is the timing of the tapping. Just after turning on the power to the camera start tapping on the lens casing - not hard - just a light tapping. And don't tap on the glass lens itself -- you don't want to really break it.
May 15, 2009 | Canon PowerShot SD600 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
The zoom lens won't close. It says to restart computer, but won't do anything when I try to turn it on. It's a canon power shot SX100 IS
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 27, 2008 | Canon Cameras
Lens error Help please
The Lens Error usually means the lens has sand or another obstruction stopping it from retracting.
Nov 07, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot A630 Digital Camera Logo
166 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
