What does this mean?
Write error at 193856 (16) - Code 06 29 00 [Unit attention, Power On or Bus device reset occured]
  • thewolfdog12 Jan 09, 2009
    Actually I figured my burner was having problems burning at 12x speeds so I tried at 4x and it burned all the way through.
  • Dan rogers
    Dan rogers May 11, 2010
    This really could be so many things inside your computer physically and in the software/bios that you would be better taking it to a qualified repair shop or try chatting with one of our pros so they can walk you through this step by step without interruption.
  • 104 Answers
There might be a hardware problem on your device
Posted on Nov 29, 2009
51.2m error
This is a problem with the magenta cartridge in your printer. According to hp's website, you can try the following to fix it:
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and turn it on again.
  3. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  4. If this message persists, contact an HP-authorized service or support provider.
Hope this helps
Please rate this solution, thanks!
Mar 09, 2011 | HP Color LaserJet 5500 Printer
Code ereur 59
A code error 59:
Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action
  1. Press the green c00099346.jpg (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    3. When the memory starts counting, press and hold the green c00099346.jpg (Select) button.
    4. Continue holding the green c00099346.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press c00099347.jpg (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press c00099346.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Mar 02, 2011 | HP LaserJet 5550DN Printer
How to reset error code c21 in the Toshiba e studio 166?
how can to reset error code c21 my toshiba e-studio 166 printer
Feb 28, 2011 | Toshiba e-STUDIO166 Printer
What does that code mean for the 2002 dodge durango "no bus"
The various computer and electronic modules on your vehicle communicate over a "communication bus". This network or bus, is what allows them to send electronic messages back and forth so that they can "talk" to each other. When you get the "no bus" indication is means that this communication network has failed and the modules can no longer "talk" to other. At the same time this occurs all kinds of weird electrical issues are likely occur and this is all due to the bus going down.
Oct 13, 2010 | Dodge Durango Cars & Trucks
Code error h2
Hi
Error code H2 means fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor or due to fusing lamp. To resolve this error try and reset the unit by entering the service mode--
press # - INTERRUPT - C - INTERRUPT
then
14
start
If this resolves your issue then try restarting the printer and try the reset again. However, if reset is not helping you then you
Oct 09, 2010 | Sharp AR-5316 Advanced Digital Imager...
What does code F DL code mean?
Hi
Thanks for using FixYa. Error FDL means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please do rate the solution if issue is resolved else post a comment for assistance.
Thanks
Rylee
Jul 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am trying to program my motorola mt1000 radio but I am getting a error message " SERIAL BUS ACCESS ERROR 004" I need help
This error message means that there is software/hardware problem. It can be that you have not programmed it in the right way. So, an error occurred while you were programming it. It's better to reset the unit.
Feb 14, 2010 | Motorola For MT1000 MTX800 MTX90010v...
Washer stopped with error code f1
Was the error code F01?
If it is ther error code means EEPROM ERROR
A communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. and or
PUMP DRIVE ERROR
The pump driver fails to activate.
and or
MAIN RELAYS ERROR
One of the main relays is not working properly.
Could be cause by a power glitch. unplug unit wait 10 seconds and plug unit back in. If code returns replace Central Control Unit (CCU)
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does the trouble code on a cannon printer
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Thanks.................
Jul 17, 2009 | Canon PIXMA MP170 All-In-One InkJet...
BUS DEVICE RESET FUNCTION
the bus settings may be the settings that have been changed by roxio, if you havent uninstalled the previous burning programme. Try uninstalling any burning programme you have, restart the pc and install the programme you require. If it continues you may need to uninstall the drive, by way of :- my computer>properties>hardware tab>device manager and look down list to dvd/cdrom drives and click '+' sign to your dvd line and right click and uninstall. Restart pc and it will automaticaly install again, ready for use.
May 11, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Computers & Internet Logo
David Payne
David Payne
