Question about Bosch Evolution Pro-Style 700 HDS7282U Stainless Steel Kitchen Range
Control panel on my Bosch 700 series gas range not lighting up
The contol panel only has a flashing red light on the left hand side of the control panel. The light is not the the lock on the right side of the control panel. There is power going to the control panel. Any ideas??
  • 1314 Answers
SOURCE: Gas Range
touch the clear/off pad then try again if that doesn't work then cut off the breaker for 30 secs then reset the clock and see if the code resets
Posted on Jan 09, 2008
SOURCE: All lights on the touch panel are flashing and a continous beeping sound
bosch 700 series range. So far unplugging the range and waiting several minutes to plug back in reset everything like rebooting a computer.
Posted on Apr 30, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag MGR5775QDS Gas Range Control Panel Problem
sure you can relace yourself, the part number, if you dont already have from previous repairs can be obtained fromthe sears website, or by calling manufacture direct. as far as a schematic there should be one located behind the range.
Posted on Feb 21, 2009
  • 457 Answers
SOURCE: bosch hgs232uc gas range oven not working.
unit has to be configurated when you replace board or it wont work. nyc appliance repair can repair it for you.
Posted on Feb 26, 2010
  • 30 Answers
SOURCE: control panel non-responsive
replace them sound shorted
Posted on Apr 22, 2010
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
Left side two burns do not ignite
Check the ignitor unit, If the other side works, maybe a wire has come off the ignitor feeding the left side.
Sep 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
Bosch eletric hob schott ceran one side flashing and not working
Will need a control panel for the faulty side.Easy repair very expensive part
Jun 11, 2009 | Audiovox Bosch 718 World Cellular Phone
Vulcan fryer gas control knob will not turn
700 SERIES GAS VALVE MUST BE CHANGED COMES WITH NEW KNOB PRICE OF GAS VALVE IS ABOUT $105.00
Nov 16, 2008 | Vulcan EF3 Deep Fryer
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Oct 05, 2008 | De Dietrich Dishwashers
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Dec 19, 2006 | Bosch HGS435UC Gas Kitchen Range
Bosch Evolution Pro-Style 700 HDS7282U Stainless Steel Kitchen Range Logo
222 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
