Question about Olevia LT32HVE 32 in. LCD Television
Picture but no sound. however we have dish network and when i push an incorrect button it makes noise and i can hear it coming out of the TV
  • 362 Answers
Hi nana bannana,
I believe the problem is with the wires that connect the two, check yor connection. It sounds as if the video and audio connections are switched. If you are using a cable that has a red, white and yellow plug you have the yellow plug (video) plugged into an audio port (white and red)
Let me know what you find. lone99star
Posted on Jan 09, 2009
Toshoba tv dvd combo picture on my tv will not work but picture on the dvd works great
I assume you mean you have a Toshiba TV with a slot for DVD play also. You don't say whether your TV is connected to a dish, cable box or antenna. Regardless of which it is, the fact that the TV produces a good picture on DVD but not on regular TV means one of two things: Either you have the TV hooked up incorrectly OR you do not know that you must change the SOURCE from DVD to TV to get a picture. That is done on the remote with the source button. Typically, the remote will have DVD, TV and AUX (one or more) as you cycle through them by simply pushing the source button again and again, If that doesn't work, you've got the TV hooked up incorrectly and/or it just happens to be set at DVD for the source. Normal hookup would involve HDMI out from the cable box, dish or whatever to HDMI in to the TV. Play with the remote "source" button. You'll figure it out. . .
Jul 02, 2017 | Televison & Video
I'm hooked up tp Dish Network an hit wrong button on top for volume and now pic is gone. in lower left corner says no signal., but dish is working, just no picture on screen
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to change your TV back to the proper input or channel. If the TV remote is not working to change the channels you can also use the buttons on the front of the TV. First look for a button listed as either input, TV/video, source or AUX. When you press this button it will start cycling through all the inputs available, make sure to cycle through them slowly because it make take a couple seconds for the picture to come in. If you do not find a picture on any of the inputs you are going to need to try the different channels. Normally for a TV where the receiver box is the TV should be set to channel 3 or 4. Once you have found your DISH Network picture you will want to make sure to push the SAT button on the DISH remote so that it doesn't change the TV channel again. I hope you find this information useful and if you have any further questions or concerns please let me know. Thanks. :)
Oct 22, 2011 | Craig CLC501 15 in. TV
Pushed recover button now tv wont go off video
Hi! My name is Becki Barned, with Dish Network customer service! It sounds like there could be a few issues that you are experiencing. Now, regardless of what you are actually seeing on the tv, you will want to unplug the receiver box from the power source. If you have no picture, that should resolve it, and if you are stuck on a certain channel, this should also resolve it!!!!
Dec 14, 2010 | DISH Network 135899 Remote Control
I have a samsung lcd 650 series tv and a dish network remote. I can use the remote to change channels and control power and volume to my TV. I cannot change the picture size and the picture on most...
We would be happy to help get that fixed. It sounds like you may be in the incorrect screen format. Press the * located below the number 7 on the DISH Network remote control. Cycle the formats to determine the screen format that fits best.
We hope that this fixes it for you. Thanks so much for choosing DISH Network!
Phillip Chang
DISH Network Customer Service Department
Oct 27, 2010 | Samsung AH5900092W Remote Control
No sound coming out of tv. I have tried 2 tv's s i a guessing it is the reciver. i have tried reseting it many times and the volume. But the tv shows a picture.
mikepiscitel,
If you are not getting sound on your tv, you could check your cables from the receiver to your tv to make they are secure. Have you tried a DVD player or VCR to make sure you get sound from those components? If you do get sound on those, then it might be the receiver, if the cables are secure.
Ray Calo
DISH Network
Sep 07, 2010 | DISH Network 311 DTV Receiver
No picture just sound thru dish network
There are a few reasons that this could happen. The main reason would be that the tv is on the incorrect channel or input. You will want to make sure that if you are at TV1, the channel is on 3 or 4, and an input if needed, such as VIDEO 1 or 2. If at TV2, the channel needs to be on 60 or 73. Cabling is another reason this could be. You want to make sure that if you are at TV1, all cables going from the receiver to the TV are connected on the back of the receiver at the green TV1 location. For TV2, the cable needs to be connected to the HOME DISTRIBUTION output on the back of the receiver.
Becki Barned
Jun 01, 2010 | LG 52LG50 52 in. LCD HDTV
I pushed some button on my remote and now I can't get my tv to work. Any suggestions?
Guest,
If you are not getting a picture on your TV, check to see which light on the remote lights up when you press the "Select" button. If anything button other than the "Sat" button lights up, the remote is not in satellite mode. Pressing and releasing the "Sat" button on the remote will put the remote back in satellite mode. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network 721 DVR Remote Control
RCA 32'' TV .....Good Picture but No Sound
try changing the channel you outputing to. go to your tv1 location hit the menu button and choose number 6 system setup then number 1 instalation then number 5 modulator setup then change tv2's channel to like 65 then select done go to your tv2 put on 65 and see if this helps issue
Nov 14, 2008 | Televison & Video
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Olevia LT32HVE 32 in. LCD Television Logo
73 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
