Question about HP LaserJet 3055 All-In-One Printer
Is my fax shutting off?
This is re incoming fax function on my 3055. Several times per day, fax rings 3 times only and no fax is received.. It appears that after the 3rd ring it shuts off. I have had test faxes sent and some do arrive successfully....other contacts tell me that they have made multiple attempts to fax but faxes do not arrive. Why would machine shut off after 3rd ring? I'm stumped!
    Genius:
  • 2,120 Answers
Make sure your your phone line is ANALOG not DIGITAL
Posted on Jan 10, 2009
Always receiving fax
You will need to select manual under the RX settings. Under fax settings. Rx means receive, Tx means transmit. The fax settings are under additional functios * on keyboard. Or you can put a switch in the phone line. When you tell it manual you will have to be there to receive a fax. In the fax settings there are several options on how and when you receive a fax. Ring settings forward settings things like this can customize your fax. You can set how many rings before it answers. Leave it on auto and set more rings so it won't answer until that many rings. Default is 2 or 3 rings. Give it 5 that will give you time to answer and you can still get faxes when your not there. Play around with it and figure out what works for you.
Feb 17, 2015 | Canon Pixma MX410 All-In-One Printer
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Repeating incoming faxes several times
Under service mode FUNCTION and Data registration and #, find clear function and select ALL.
After that reenter your sett.
Jun 16, 2010 | Canon L220 Plain Paper Laser Fax
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
Hp-laser jet 3055
hi, just try to reset the memory the of fax. i think that's the cause that's you cant send and recieved fax..i hope it would help you...
Oct 20, 2008 | HP LaserJet 3055 All-In-One Printer
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Answering machine turns on and I can't receive faxes.
Why don't you consider a separate Phone/Fax switch. It will answer first ring and detect a fax and then ring the fax/printer you can set that to one ring as well, otherwise it ring the answering machine that is plugged into that and you can set that to answer on 3 or 4 rings. Then you have time to pickup phone if you are available.
Thanks what I do. The boxes are about $30 They are fairly cheap.
Nov 24, 2007 | HP LaserJet 3055 All-In-One Printer
My hp 3055 has not been receiving any faxes
The only thing that I can think of for you to do is to completly delete it from your computer & then re-download it. Only do this if you get no other resolution. Or you can call 1-800-474-7739 for hp technical support. I just did & they were a great help to me!
Jun 05, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
