Question about Epson Stylus Photo R300 InkJet Printer
How do I remove a waste ink cartridge from my Epson Stylus Photo R300 printer?
  • alicegibson Jan 09, 2009
    Actually, I am getting an error message "General Error consult manual" After researching, it appears there is some sort of "waste" to be cleared and I am not sure what this is about.
    Novelist:
  • 140 Answers
The cover on the printer should lift up so that you can see your ink cartridges. Also once you lift the cover, you should notice that there is a picture step-by-step instruction for doing this. Anyway you will notice that the print head with the ink cartridges on it are all the way to the left. With the power off, put your fingers on the cartridges and pull the printhead and cartridges to the center right in front of you so that you can get to it. The cartridge that you want to replace will lift up and back as they are snapped into place and held gently with a tab. Pull on it gently and it will come out. Replace it with the new one and be sure you take off a little cover that the new will have. Close the lid and power it back up and you're back in business. God bless.
Posted on Jan 09, 2009
How do I change the ink cartridge on my Epson R300 photo printer
You can find the manual here:
http://files.support.epson.com/pdf/r300__/r300__u1.pdf
on page 90 - 91 there is a description how to replace the ink cartridges.
Mar 11, 2011 | Epson Stylus Photo R300 InkJet Printer
After cleaning it and replacing numerous black cartridges, My epson stylus r300 printer won't print black ink. What should I do?
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Nov 18, 2010 | Epson Stylus Photo R300 InkJet Printer
How to install new cartridge
Make sure the printer is on and not printing. Have a new cartridge handy, as this installation should be done in one session.
Note if the "cartridge is low" or the "cartridge is empty" light is activated on the printer and follow the specific instructions carefully in the document below for each situation.
See "Removing and Installing Ink Cartridges" in the following document:
Epson Stylus Photo R300 - Removing and Installing Cartridges
Mar 01, 2010 | Epson Stylus Photo R300 InkJet Printer
Epson Waste Inkpad?
That is a container placed underneath the nozzles that collects all of the excess ink so that it doesn't droll on your desk. If you are a technician, you can remove it yourself, clean it up (wash it with water and soap) and then place it back in. Or you can go with the printer to specialists and have them clean it up for you.
Feb 15, 2010 | Epson Stylus Photo R300 InkJet Printer
How do you change ink cartridgesfor the epson r300
Press Ink button;
Select Ink Cartridge Replacement
Press OK
changer cartridge
then press OK
And wait for initializing
Dec 18, 2009 | Epson Stylus Photo R300 InkJet Printer
Waste ink pad on epson stylus photo r300
The Epson Stylus series of printers do not have this feature. You can find out more inso at www.epson.com. Hope this helps.
Jul 08, 2009 | Epson Stylus Photo R300 InkJet Printer
Saying a part of your printer has come to the end of its working
This means that the waste ink pads in the base of the printer are full and need to be replaced.
There is a much easier solution which is described here with information on how to redirect the waste ink and reset the waste ink counter in the printer so the printer will allow you to print again.
If you have any problems, please add a comment and I'll do what I can to help.
Mar 25, 2009 | Epson Stylus Photo R300 InkJet Printer
Red light is plinking
this mean that your printer waste pad is full and your printer needs to be reset go to this website http://www.ssclg.com/epsone.shtml
this will reset your printer
plz rate me
Mar 23, 2009 | Epson Stylus Photo R300 InkJet Printer
Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Jan 08, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson photo r300
the ink cartridge is on the carriage, as you lift the lid of the printer you should see the cartridges to the right.
May 28, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
162 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
