Question about HP Color Laserjet 3550 Printer
Hp 3550 fuser error 50.1 and it is cold. - HP Color Laserjet 3550 Printer
  • 390 Answers
The fuser error 50 means that the fuser heater lamp is blown and you need to get another one (whole assembly). I personally use printerworks at www.printerworks.com to order a new one if you want to do it yourself, otherwise you will need to drop it off at an HP Authorized repair center..
Good Luck!
Rich Lilja
Posted on Jan 09, 2009
4 Suggested Answers
rtrahan
  • 741 Answers
SOURCE: HP Laserjet 3550 Fuser Jam Error 13.20 Had it in
You need to ask them to change the fuser..The fuser is the part of the printer that actually melts the toner onto the page. Here is a website that gives you more info on the fuser so they can't B.S. you anymore..either the fuser works or it doesn't..
http://www.theofficeguide.com/toner-cartridges/faq2.html
Please rate this solution thanks.
Posted on Mar 25, 2009
FixinFax
  • 3085 Answers
SOURCE: hp 3550 fuser error
Have the fuser replaced.
Posted on Jul 10, 2009
  • 37 Answers
SOURCE: laserjet 3550
Yes they will
Posted on Dec 09, 2009
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
We have an HP 3550 color printer that has a 50.1 Fuser Error. Will replacement of the fuser correct the problem?
The most common reason that causes a fuser error is its failure to reach operating temperature. If the fuser area can be accessed, check to see if there is noticeable heat present. If not, the fuser may not be getting the required voltage to bring it to temperature and you may need technical help to determine the exact cause of the error.
Aug 24, 2010 | HP Color Laserjet 3550 Printer
50.1 fuser error not fixed by instruction on machine; HP color laserject 3500
17 posts - 8 authors - Last post: 23 MarWe are getting a 50.1 fuser error with our Colour Laserjet 3500 printer ... fuser from HP in the UK, but was told that they are not currently available ... hi I have the same problem error 50.1 with two machine 3500/3550 ...
www.fixyourownprinter.com/forums/laser/31146
Dec 04, 2009 | HP Color LaserJet 3500 Printer
Hp 3550 fuser error
Jul 09, 2009 | Office Equipment & Supplies
Mar 25, 2009 | HP Color Laserjet 3550 Printer
HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Mar 11, 2009 | HP Color LaserJet 3500 Printer
Hp 3550 fuser problem
try this
Oct 29, 2008 | HP LaserJet 3550 Printer
1,008 people viewed this question
Ben Johnson
