Question about Durabrand DUR7 Portable DVD Player
2.0 CH USB Powered speaker System
USB is plugged in. NO sound. So is the USB for power only? My computer does not have the receiver for one banana plug
  • 47 Answers
Yes.. in those types of speaker systems the usb is for just power.. and the "banana plug" is the audio jack.. there should be some kind of audio outpu on your computer .. it is usually located in the back near the middle or bottom.
Posted on Jan 09, 2009
What could I use to connect my speakers to the back panel of the STR DH700. My home was prewired with speaker wires for surround sound. I used banana plugs for the other speaker wires but finding hard to...
Had a set of bose AM-10 that I had to take back cuz Sony said that their receivers needed a powered sub woofer. got AM-15's and hooked them up-AMAZING SOUND.
Dec 08, 2009 | Sony STR-DH700 A/V Receiver
I have a Pioneer DQ-4000 receiver. Honestly I am
I think what you are looking at is referred to as a banana plug connector. You do not need to buy these connectors to make this work. If you unscrew the plastic connector out far enough, a hole from the side opens up so you can put your copper conductor through and tighten the plastic peice down. The banana plug is probably better for easy connection but using this method is just as good.
Oct 28, 2009 | Pioneer Audio Players & Recorders
2.0 CH USB Powered Speaker System
Yes the JACK is for audio and the USB for power.
Jul 18, 2008 | Audio Players & Recorders
No audio device detected
Ok when you plugged in the USB sound did it "see" it... did it ask for "Drivers" Because this device MUST have drivers.. also ya may have to disable any onboard sound device ya may have via the BIOS setup menu. Generally these USB sound devices are real easy to install and use.. try it on another PC to be sure it is OK.. GL
Jun 05, 2008 | Durabrand 5.1 Surround Sound Computer...
2.0 CH USB powered speaker system is not working. We have plugged into the computer and cna't get any sound
You must to buy and use an active USB hub.It's like the ordinary USB,but have own power supply.I think your speaker haven't enough power,so try to use the active HUB!!It works.
You can purchase it in any PC shop,or the Internet shop etc.
Mar 16, 2008 | Computers & Internet
2.0 CH USB Powered Speaker System Problems
For speaker, No, you don't.
as long as your sound card is working, speaker should work
Mar 01, 2008 | Audio Players & Recorders
Speaker won't work
First things First:
1) check your connectors back on the PC, I presume you use windows XP and sound drivers installed **
2) plug the speakers cable on back or front of your PC in the green (usually) connector.
3) see if sound is NOT mute on mixer , multimedia in control panel.**
4) If you can Enter your BIOS, try to enable sound, for onboard sound, if apply**
good Luck
Jan 20, 2008 | Audio Players & Recorders
Speakers won't work
some time if your operating system does not support your usb itself.
you install its software first by try on web
Dec 27, 2007 | Audio Players & Recorders
Durabrand 2.0 CH USB Powered Speaker System
Balance needs to be set up; ie, the individual channels need to be adjusted to properly hear your tunes.....accordianman
Oct 30, 2007 | Denon AVR-987 Receiver
Durabrand 2.0 CH USB Speaker System
Hi, Based on your post/description, the Durabrand 2.0 CH USB Speaker System is a basic external speaker that plugs into your PC's speaker/headset output (green jack). It is supposed to get its power from the +5VDC supplied by the USB port. Some USB port have current limiting therefore it can be anywhere from 10 - 500 mA. The power requirement of your external Durabrand speaker maybe beyond what the PC's USB ports can supply. It does not need to be recognized by the OS since it only connects to the USB to get power but there is no data interaction. Perhaps what you can do is get an external +5VDC power supply whose output is in USB type connector. The current rating would depend on the requirement of your speaker. Offhand, if the speakers are not that big, probably a 1 Amp would do. This is of course assuming that the Durabrand speaker system is fully functional. If with an external power supply it is still a no go and you have verified that sound do come out of your green jack (with the use of an ordinary headset), then the Durabrand is defective. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 22, 2007 | Denon AVR-987 Receiver
Durabrand DUR7 Portable DVD Player Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
