Question about Black & Decker BDL400S Bullseye Crosshair 90 Degree Auto Leveling Interior Line Laser
The laser light on my black & decker bdl500 stopped working
I replaced the batteries and there is power but the laser inside seems to be stuck and does not move. the laser light stopped working after it stopped moving. I removed the four screw on the back but there is something in the middle holding the unit together. I wanted to take it apart before I replaced it to see if there is something loose or out of place but I can't get it apart.
I checked prices and it is cheaper to throw it away than send it to be repaired but I thought I would give it a fixit try before I threw it away.
  • 4 Answers
I had the same problem with mine. I took it apart and inspected it. Mine was a loose connection and after some fiddling with the wires the laser came back on. Put it back together and haven't had a problem with it since. Hope it helps.
Posted on Mar 30, 2015
2 Suggested Answers
cesar_quant
  • 61 Answers
SOURCE: CHARGED THE BATTERY AS INSTRUCTED, UNIT DOES NOT WORK
check the factory date.. the batt might be bad due to time, check the polarity conexion to the batt might inverse. i suggest u try another batt..
Posted on Mar 15, 2009
Black decker problems
Either the switch is defective or the wire inside the pole is broken
Jun 02, 2014 | Black and Decker USA Black & Decker 20v...
My 24 volt black an decker battery charger want charge
Batterys have a life span associated with them. Typically about 2 years depending on how often you use them and your charging habits. The newer batteries(in the past 4 years) do not have memory, but since it is a black and decker and it is low cost item they may have used an older technology. I am assuming you have checked the obvious such as the charger does work. Battery is inserted properly. An easy task to try would be to buy a new battery and make sure you discharge it before you charge. Run your drill till it stops. Then charge it to see if the charger is working. If not, then you have a charger problem. If so, there may be fuse inside that can be replaced or something simple like a solder joint broke.
Hope that helps
Jan 22, 2011 | Black & Decker Black And Decker FS24C...
My porter cable 19.2v model 8605 battery charger
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Jul 24, 2010 | Porter Cable 19.2V Drill Kit
Black and decker power drill #7193 not working
Check to see if the fwrd/rvrse switch is fully engaged in one direction.
May 28, 2010 | Black & Decker Drills
Microsoft wireless notebook laser mouse 6000 not working
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still no workie. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the mouse's opening for the battery appeared to be bent down (away from the contact on the battery tray). So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Jun 26, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
The light don't come on and want charge my 12 volt battery
My charger has a fuse located on the circuit board inside the unit....when mine stopped working, it was the fuse...replaced it and it is working fine for one battery, the other blows the fuse every time....bad battery.
May 20, 2009 | Black & Decker Black And Decker 12 Volt...
Mar 15, 2009 | Black & Decker Black And Decker 2 Million...
Black and Decker B2300 Bread maker problem
Im having the same problem, anyone find the solution?
Jun 20, 2008 | Black & Decker B2000 Bread Maker
Blender stops working
I also have the same problem...it is brand new...worked 3-4 times and stopped. Spent $65 for a nice blender. I will also NEVER buy black and decker again.
Dallas, TX
Oct 12, 2007 | Black & Decker BL1900R Blender
Black & Decker BDL400S Bullseye Crosshair 90 Degree Auto Leveling Interior Line Laser Logo
556 people viewed this question
Top Black & Decker Measuring Tools & Sensors Experts
Vuk B
Dennis
frankrome
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
