Question about Malber TD700 Electric Dryer
Dryer has power but won't start
I've check the door and it's properly closed. The drum turns with some degree of resistance (so belt likely isn't broken) but it won't start on any settings. I have no recollection of anything happening to cause it to stop working. Is it a start capacitator issue? Dryer is only 2 years old and hasn't given us any problems to date.
  • Cviv Jun 08, 2008
    My Malber tumble dryer - TD 700 - 220 volts has power but won't start. A technician identified the burnt start capacitor as the problem. Where can I find a replacement part?
  • Anonymous Mar 27, 2009
    maytag model# PYE4500AYW-
    dryer has power going in, timer clicks, but won't run. does not make any other noise.
  • 883 Answers
Have you verified that power is actually getting to the unit? the symptoms to describe a "start capacitor issue" are excessive current draw and hum noise when starting. your dryer most likely uses a different starting method: motor has 2 coils, one for start, one for run.
Posted on Jun 04, 2007
Samsung dryer DV42h5000ew won't power up
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
Tip
Whirlpool Dryer Various Test Procedures - Part 1
TEST #1 Supply Connections
This test should only be done after confirming proper voltage at the outlet.
1. Unplug dryer or disconnect power.
2. Remove the cover plate from the back of the dryer.
3. Check that the power cord is firmly connected to the dryer’s wire harness.
4. Access the machine control electronics without disconnecting any wiring to the control board.
5. With an ohmmeter, check for continuity between the neutral (N) terminal of the plug and P8-3 (white wire) on the machine control board. If there is continuity, go to step 6. If there is no continuity, disconnect the white wire of the harness from the power cord. Test the continuity of the power cord neutral wire . If an open circuit is found,
replace the power cord. Otherwise, go to step 6.
6. In a similar way, check the continuity between the L1 terminal of the plug and P9- 2 (black wire) on the control board. If there is continuity, go to step 8. If there is no continuity, check the continuity of the power cord for power cord’s L1 wire. If an open circuit is found, replace the power cord. Otherwise, go to step 7.
7. Replace the main harness.
8. Visually check that the P5 connector is inserted all the way into the machine control electronics.
9. Visually check that the user interface assembly is properly inserted into the front console.
10. If both visual checks pass, replace the user interface assembly.
11. Plug in dryer or reconnect power.
12. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
13. If indicators still do not light, the machine control electronics has failed: Unplug dryer or disconnect power.
Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
TEST #2 Machine Control Power Check
This test is used to determine if power is present at the machine control electronics.
NOTE: The drum light is controlled by the machine control on all models.
2. Open the door.If the drum light illuminates, then power is present at the machine control, and it is functional. Go to TEST #6. If the drum light fails to illuminate, do not assume the machine control electronics needs replacement. Several conditions may cause the drum light not to illuminate, including a bad bulb. If the drum light does not illuminate, go to TEST #1.
TEST #3 Drive Motor Circuit
This test will check the wiring to the motor and the motor itself. The following items are part of this motor system:
Harness/connection Belt/belt switch Drive motor Centrifugal switch Door switch Machine control electronics
2. Access the machine control electronics and measure the resistance across P8-4 and P9-1.
If resistance across P8-4 and P9-1 is in the range of 1 to 6 ohms, replace the machine control electronics.
Otherwise, go to step 3.
3. Check the wiring and components in the path between these measurement points by referring to the appropriate wiring diagram and strip circuit in Section 7.
4. Check the belt switch and drive motor. Access the belt switch and drive motor by removing the front panel/drum assembly. Slowly remove the drum belt from the spring-loaded belt switch tension pulley, gently letting the belt pulley down.
5. Remove the white connector from the drive motor switch.
6. Check for the resistance values of the motor’s Main and Start winding coils. NOTE: Main and Start winding coils must be checked at the motor.WINDING RESISTANCE ω CONTACT POINTS OF MEASUREMENT
MAIN 1.4–2.6 Blue wire in back at pin 4 and bare copper wire on pin 5 of black drive motor switch
START 1.4–2.8 Blue wire in back at pin 4 and bare copper wire on pin 3 of black drive motor switch. If the resistance at the motor is correct, there is an open circuit between the motor and machine control electronics.
Check for failed belt switch. If the Start winding resistance is much greater than 4 ohms, replace the motor.
7. Check the belt switch by measuring resistance between the two blue wires while pushing up the belt switch tension pulley.If the resistance reading goes from infinity to a few ohms as pulley arm closes the switch, belt switch is OK. If not, replace the belt switch. If belt switch is OK and there is still an open circuit, check and repair the wiring harness.
8. Door switch problems can be uncovered in the Door Switch Diagnostic Test; however, if this was not done, the following can be done without applying power to the dryer. Connect an ohmmeter across P8-3 (neutral, white wire) and P8-4 (door, tan wire).With the door properly closed, the ohmmeter should indicate a closed circuit
(0–2 ohms). If not, replace the door switch assembly.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
GTWN4250D1WS WON'T START. CHECKED THE POWER CORD, ALL IS WELL. WONDER IF THERE IS A FUSE OR SOMETHING ELSE TO LOOK FOR.
Troubleshooting Why Your Dryer Won Start PartSelect com Electric dryer no start does nothing
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 01, 2017 | Dryers
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 24, 2014 | Kenmore Dryers
Whirlpool dryer LER7646E02 will not turn on
Could be something as simple as a broken belt or door switch is broken. Open top and check if the belt is still in tact. If yes, then check door switch to see if electrically closing when door is shut (check resistance with power off).
Jan 11, 2014 | Whirlpool Dryers
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a Kenmore Elite Gas Dryer in which the drum does not turn. After selecting the mode switch and depressing the start button, the dryer only hums with no turning of the drum.
Disconnect the dryer from its power source before servicing!
Inspect for a brokren drum belt. The humming noise is probably the motor running with no belt. You can easliy identify this by opening the dryer door, rotate the drum by hand by using a baffle as a gripping point. If the drum rotates freely, the belt is gone. If you feel a slight degree of resistance or drag, then you will have to go internal to inspect for the belt and associated rollers and idler pulley to make sure they are free rolling.
Jun 07, 2008 | Dryers
Malber TD700 Electric Dryer Logo
223 people viewed this question
Top Malber Dryers Experts
Craig Butler
Craig Butler
Justin Duby
Justin Duby
ray gallant
Are you a Malber Dryer Expert? Answer questions, earn points and help others
