Question about HP LaserJet 2430n Printer
HP 2430n Service Error 494C02
When I turn the printer on, it will print the document, but for printing a 2nd document I get the service error 494c02 message.
  • atrowbridge Jan 09, 2009
    This fix is a little out of my league as the printer is connected to a network in our school district, but at least I know this is something that we should contact our IT dept. about since we are not too tech savy here at our elementary school.
    Novelist:
  • 125 Answers
Hi atrowbridge:
The error code 494c02 is a firmware issue and needs to be updated. You can go to www.hp.com for the latest firmware updates for your printer.
pdouglasss
Posted on Jan 09, 2009
Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Jan 14, 2011 | HP LaserJet 4700 Printer
What is service error 49.4C02? HP Laser Jet 2430n
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font. fix printer error 49.4c02
Sep 07, 2010 | HP LaserJet 2430n Printer
Non hp suply installed-error message for hp 2420
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jul 27, 2010 | HP LaserJet 2430n Printer
Printer status- error offline
first go to services.msc refresh the spooler service. then insert the printer disc in to the computer . do a level 2 uninstallation .
restart the computer then again again reinstall the software issue will resolved
Aug 03, 2009 | HP PSC 1210 All-In-One InkJet Printer
Just stoped printing;print cartridge problem
Remove print catrige and clean it with cotton cloth then refix it.
May 19, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
HP LaserJet 3200se 79 service error 694:SM.C
1st shut the printer off
2nd Disconnect it from the Computer
3rd turn it on
Does the error still occur?
If it starts properly print a configuration page.
If this is possible you have a Printer Driver issue.
Replace the Print Driver.
If it still has the error when the printer is NOT connected to the Computer then you have a firmware issue most likely.
Nov 06, 2008 | HP LaserJet 3200se Printer
Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
49 4C02 error
turn off the IPP protocol, and turn off Multicast IPV4
The 49.xxxx errors are indeed related to firmware and the formatter and can indicate faulty firmware or formatter... but are almost always triggered by some kind of communication that the machine doesn't know what to do with... thus generating an error.
Power fluctuations (not clean power), or random noise (RFI/static) transmitted on network or printer cables can also cause this problem. If your unit sits on a line of power that is shared with other devices (another printer/copier or a group of computers or a vending machine or cooler)... move it to a dedicated power outlet.
If it's caused by signals the machine is receiving, it can be tricky to correct.
Feb 19, 2008 | HP LaserJet 4350TN Printer
HP LaserJet 2430n occasionally prints goblety-gook
ISSUE: When printing from the computer, you receive a line of garbage or all of the printed output comes out on one line. SOLUTION: See the following:
  1. Perform a self-test to be sure that the HP LaserJet printer is functioning properly. If the self-test is not correct, remove all cables and accessories (if any) and print a self-test again. If the self-test is still not correct, service the printer. If the self-test is correct, go to the next step.
  2. Reseat or replace the cable. Check the cable for bends or pressure applied by objects resting on the cable. A faulty cable or cables that do not meet the IEEE-1284 Standard can cause print defects by distorting signals.
Jan 09, 2008 | HP LaserJet 2430n Printer
HP LaserJet 2430n Printer Logo
668 people viewed this question
Seeker5211
Seeker5211
